CDI Interference
Old 12-20-2009 | 09:09 PM
Default CDI Interference
Hey guys....I've got a problem with my newly installed engine Zenoah G26 with CDI....I'm having glitzes on my servos while running the motor. I using a 40 mhz receiver on my plane and using a 4.8v 2,400mAh nicad batteries on my CDI. I located the CDI box on the front section at the back of the firewall while the battery located near it. The control receiver is located at the middle of the fuselage together with it's batteries. If you guys have encountered the same problem and has corrected it please let me know what
you have done. Thanks a lot.
Old 12-20-2009 | 09:53 PM
gadix's Avatar
Default RE: CDI Interference
komustaka? mabute'?
what push rod do u use for the TH servo?
usually when u use a metal one than RF noise can interupt the RX signal.
try to seperate the TH servo lead wire from any other harnes if ever
u can try using a ferrit ring on the TH wire to filter any Rf noise
http://www.lightingforaeromodellers....ges/F_RING.jpg
hope that this is helps u
Old 12-20-2009 | 09:55 PM
All Day Dan's Avatar
Check out this thread. Dan.
http://www.rcuniverse.com/forum/m_93...tm.htm#9347035
Old 12-20-2009 | 10:17 PM
hi...gadi...Thanks for the quick reply...actually my set up on the throttle push rod is made of steel wire. I will change the
throttle push rod to nyrods and see if it's still the same....I will let you know if I have solve the problem. Thanks a lot. mandx
Old 12-20-2009 | 10:25 PM
Hi Dan...Thanks a lot. I will let you know if it works. SALAMAT.
Old 12-21-2009 | 12:18 AM
hi..gadix....you got it right...I already fixed the throttle pushrod changed it to nylon rods and works perfectly fine. Thanks a lot
for helping me out on this.
Old 12-21-2009 | 12:23 AM
hi...Dan Thanks a lot I have already fixed the problem. I changed the throttle pushrod from steel wire to nylon push rod and works
okey. I also checked the sparkplug cap that was a little bit loose. Snapped it to place and the problem was gone. Thanks to you guys.
Happy Flying, guys.. mandx
Old 12-21-2009 | 03:32 AM
gadix's Avatar
excellent
do a range test prior to flying with closed antena just to make sure!!!
enjoy
