US Engines 41 cc
Old 02-07-2010 | 12:07 PM
G.Barber's Avatar
Default US Engines 41 cc
I picked up a 41 cc US engine from an auction over the weekend, and I am wondering two things. First, does anyone have part? Second, how much is too much to spend to fix it? The bearings appear to be all good, except the spring starter- the spring is shot as well, so I am in need of mainly the crank seals, carb gaskets, and crankshaft thrust washers. Is it worth repairing?
Old 02-07-2010 | 01:33 PM
My Feedback: (25)
Default RE: US Engines 41 cc
B & B Specialties has parts. I wouldn't worry about crank seals and thrust washers. Just rebuild the carb with rebuild kit...remove the spring starter and start it with an electric starter. They will run forever if you keep it lubricated. A little heavy but reliable...certainly worth a try.
Mike
Old 02-07-2010 | 08:46 PM
B&B will have that spring as well. I find using it WAY easier than dealing with a starter.....
http://www.bennettbuilt.com/bbtable.htm
Old 02-07-2010 | 09:33 PM
w8ye's Avatar
My Feedback: (16)
If you are going to be rebuilding the spring starter set up - It is wise to inspect and re-grease the one way bearing part of the spring starter.
If the spring rubbed on the shaft, the rear seal in the engine will most likely be ruined also.
If you call Bennett he will ber asking you about this?
Old 03-02-2010 | 11:52 PM
Hi guys
Does anyone know the US engines website? Im gonna be using one on a p-51
I cant seem to find it
George
Old 03-03-2010 | 12:57 AM
G.Barber's Avatar
I haven't been able to find one, but if you need parts, I got them from the website link provided above.
I made a first attempt at starting my engine on Sunday, after repairs had been made. It popped and ran for a few minutes at low speed, but when I tried to open it up it just died. For the moment, I'm chalking it up to the cold weather, as it was around 30 degrees. However, once it warms up and proves to be reliable, I may go ahead and purchase a new spring starter.
Does anyone have a used spring starter laying around they'd be willing to part with?
Old 03-03-2010 | 07:49 AM
ORIGINAL: gabarber
Nothing gained by me personally, but Bennett does (did?) handle parts for the US 41/Quadra 42 (same motor). The spring you're after is shown about half way down the page on the following link at 14.95.
http://bennettbuilt.com/page4.htm
Old 03-03-2010 | 07:53 AM
G.Barber's Avatar
Yeah, the spring alone is $14.95, but the one-way bearings in mine are shot, so I need the whole assembly, which is $55.00. Thant's why I'd like to find a used one if possible...
Old 03-03-2010 | 11:32 PM
Hi guys
Is the RCGF 45cc Petrol Engine the same dimesions and everything as the us engine 41cc? Or how about the Fuji-Imvac 43cc ?
George
Old 03-04-2010 | 09:06 AM
w8ye's Avatar
My Feedback: (16)
About the only thing these engines have in common is that they are close to the same displacement
Old 03-04-2010 | 08:31 PM
You can get the one way brgs called "Sprague clutch" at a local brg jobber for minimum dollars. Can be pressed out and in with sockets and a vice. When pressing them in, press only on the end with the writing on it, and make sure you press them back in right way around. Otherwise, dire consequences.
