RCAero JC Engines & YDA Engines
#2053
RE: RCAero JC Engines & YDA Engines
Bob T. I think yours is the original batch from OZ. Check the plugs anyway. RC Exell ignitions don't like 6v. Especially the older ones.
#2054
Ok due to Friday nite commitments all I got to check was the plug is nkg cm-6 made in Japan the battery pack is a 4.8 4 cell sub-c 3000mh that indicates no/load 5.2 v with a load 4.9 and the ignition is an rcxl
If all goes well will get to do the rest of the checks tomarrow evening after work
and again thanks fo all of the suggestions as this old man needs all the help he can get
Cheers Bob t
#2055
ORIGINAL: rt3232
Have heard those stories about the chinese plugs I will have to look, I got this engine from Henery at the Toledo show in 2009 and as I remember he told me it had been checked out, but will deal with it
Off yo work
Cheers Guys Bob T
Off yo work
Cheers Guys Bob T
He told me the same thing about an RCGF 100........
#2056
TOM. Your'e alive. Folks are questioning your whereabouts on FG.
I have completed my first bout with competition. Got to start somewhere.
#2060
Got the day off so have been trying to give all of the suggestions a try.
First one, bat direct to ign, no change[>:] checked battery like I said it is a 4 cell sub-c 3k ma pack no load reading 5.2 with a load 5.0 even, So went bsck thru fuel system nothing found, Decided to pull carb and do a complete tair down under my 10power bench glass, Reed side first nothing that could be seen , reeds lay nice and flat on a piece of glass both ways. So on with the pump/needle side and and still nothing, removed hi/lo needles and checked them with an eyepiece they look normal and symetrical as you turn them, Fresh can of carb cleaner and back and forth through all ports all drippings on to a white piece off hard paper, nothing that I can see on the paper after it dries, Then blew out all ports with 20psi air.
Re assembled carb again cleaning each oiece as it was assembled. installed to engine, got the engine back in the bird set needles at 11/2 fueled it up, set full throtle and choke cranked till it poped reset choke and throtle about 6 cliks and we are running about 3k on the on bord tech let it warm up a bit idel down to about 1800/1900 rpm, throtle up and it goes to 6998 rpm Running a 20 X 10 Zinger Pro. great throtle responce.
Now I have 3, 8 minute runs and at all rpm's so it looks like we have resolved my problems
So untill next time all I can say is THANKS for your suggestion
Now if mother hature will just cooperate with some good weather we will try for a maiden
Cheers Bob T
#2061
My Feedback: (271)
ORIGINAL: AJsToyz
I see the JC 60 and 30 in the RCU market. I went to the JC website and they show the following
23cc evo
28cc evo
30cc evo
51cc
60cc evo
102cc
What ever happened to the 38cc ? I thought Bobs was going to be selling the JC/YDAero or does Plane Addicts = Bobs ?
23cc evo
28cc evo
30cc evo
51cc
60cc evo
102cc
Bob hobbies is not Plane Addicts. We are a seperate company working with JC engines on promoting there engines. I have performed flight test for Henry when he had the YDA and JC lines. Now we are working on our own and importing directly.
#2062
ORIGINAL: rt3232
Cheers Bob T
Cheers Bob T
I know you used every bit of that 10X magnifier. LOL.
#2063
1 Post
Hi Bob,
This is good news. Good to hear your engine is running well.
These engines like a bit bigger prop. Try 23x8 - you should get good solid performance on that size. Forget about static max RPM. You will find that in flight, you have very good midrange power on a prop of that size.
Tom:
Congratulations on your win!!
You show-off you
Tom:
You show-off you
#2064
Apalsson
I hear what you are saying about props now have an hour and 10 minute on it and it realy seams strong, also it is easy on fuel just a bit over an oz per minute, and will just have to try a few props to see what fits my flying style ahd this bird It is a 1/3 Weeks Special not sure about the weight forgot to weigh it.
Cheers Bob T
#2065
1 Post
I have been told there is a new Distributor for JC Engines in the US, or PlaneAddicts who have been frequent posters here.
PlaneAddicts has come across as a standup guy who looks after his customers and knows his stuff.
Needless to say, I assume they will take over warranty support for JC in the USA from now on?
The latest batch of YD-A engines was made by JC Engines (for Henry) so I assume PlaneAddicts will support those as well?
#2066
SC
A diaphram change is only necessary if you are using this new b.s. they are selling, ethanol, we are fortunate to have one station around here selling gas, no ethanol, that does not play hell on the internal parts of the carb. Government is about to cut out the real gas they are going to make him change over, what kind of b.s. is that.
#2067
ORIGINAL: apalsson
Milton
#2068
ORIGINAL: BadAzzMaxx
The problem with dealing in JC engines is like opening a box of candy, You never know what you are going to get and believe me I know.
Milton
ORIGINAL: apalsson
Milton
#2069
It is especially the "flavor" that is indescribable
Can't change embedded traditions in some cultures unfortunately.
#2070
Just a little up date now have 1 hour and 10 minutes of time on the engine and I realy like what I have, Next step isit to get some weather on a day off and go fly this bird. If my on line order for props shows up will us a 23 X 8 if not will be a 22 X 10. and I think I will be changing the oil to synthetic at 50 to 1 after a few more tanks just din't like the mess, worse than the birds I have to clean as a kid when working to get rides
Cheers Bob T
#2071
Good to hear Bob
It wouldn't hurt to change the oil now if what you are using is too slimy or messy. As the engine runs in it will make a mess from the exhaust anyway and you want that "black stuff" to come out of the exhaust instead of staying in the engine.
My favorite oil here for them is 40:1 of Castrol TTS (the all synthetic one) or 40:1 Redline. I use that as a standard mix for al of the 2 stroke enignes I have around the property as well as my RC enignes. I have been testing both oils side by side for a few months now with no appreciable difference between the two on engine internals (Wear or carbon buildup). I am running one in most of my engines and the "new mix" in a selected 3 engines that get flown as regularly as any of my other engines as they are in my favorite planes). I am only changing to the new blend because that particular oil is very much more readily available here than the other one and is also certified to the higher JASO standards than the existing one of the two. (We can't get Stihl Ultra or Pennzoil here [])
#2072
My Feedback: (271)
ORIGINAL: apalsson
Now to the nitty gritty of the situation lol.
We are not doing anything with the YDA line. That was Henrys baby and I use to just fly for him. Unfortunantly stuff with that went by the way side. He had the right to the motors from what I understand and I havent heard from him in a while. Maybe one day they will come pack out on the market because I really enjoyed these motors.
Now the JC engines are another story. We have picked up there product line ourselves after the Henry ordeal. We are an factory direct dealer/distributor for there line of engines.
So for warrent at this momment we are able to service the new 30cc and 60cc motors that we sell. We are working on becoming a full service center for JC engines.
As for the YDA warrenty I dont have permission or a way to get parts on these motors since I havent talk to Henry in months. So I guess these motors will have to be sent back to Bobs Hobbies for them to handle the warrenty on.
I will post pictures of the 60cc and 30cc with some info soon for everyone.
Tom
#2074
My Feedback: (271)
Hey Ari,
I have ran the motor on the bench. I have a Pitts bipe coming to put it in. I will have a bunch of info and pictures for you guys soon on both the 30 and 60cc motors.
#2075
ORIGINAL: AQualityRepair01
New?? Where have you been hiding? Lots of this country has been using it for over 20 years with no problems.
