3W 106 problems
Old 05-16-2010 | 04:41 PM
Ranfred Radius's Avatar
My Feedback: (8)
Default 3W 106 problems
I have a 3W 106 TOC that has decided that it does not want to start![:@] I believe that I'm getting enough fuel. I am beginning to question the ignition end of things! Does anyone know how probale it is that my hall sensor or the little neodym magnet in the prop hub may have gone bad?
Thanks in advance!
Randy
Old 05-16-2010 | 04:45 PM
Default RE: 3W 106 problems
It is not common for magnets to go bad unless they have been over heated.
Have you pulled the plugs and checked to see if they are firing.
Is it one of the newer ignitions that use two magnets.
Old 05-16-2010 | 06:12 PM
JLB
Pretty unlikely the magnet went bad and over the years (many of them)I've seen very few sensors go bad. I have however seen plenty of 3W ignitions go bad so that's where I would place my bets. I've had 5 3W's and every one of them has eventually had to be converted to a different carb and an aftermarket ignition which turned them into the good engines they should have been to begin with. I love their torque and power but they sure can be a PITA.
Old 05-16-2010 | 06:35 PM
3w ignitions go bad quite frequently.
Old 05-16-2010 | 07:02 PM
MetallicaJunkie's Avatar
im not a fan of 3w's anymore...ive had my share of problems with them, so has my brother.... ive far less headaches with my DL/DLE motors
Old 05-16-2010 | 10:46 PM
My Feedback: (8)
ORIGINAL: BadAzzMaxx
Oh believe me! We have had the plugs out! Can't seem to see or feel a spark. I have heard that the spark is hard to see!
Randy
Old 05-16-2010 | 10:58 PM
Just go ahead and replace it with a RCexl, if you have the two magnet it is easy as replacing the sensor.
Old 05-16-2010 | 11:12 PM
My Feedback: (8)
It's an older engine with the single magnet..
Old 05-16-2010 | 11:15 PM
Then you will have to drill and retap threads for the sensor.
Old 05-16-2010 | 11:17 PM
Or CH sells a sensor on a hose clamp that works, just does not look that great.
Old 05-16-2010 | 11:22 PM
Here is a 150 that I drilled and retap threads for the RCexl.
Old 05-16-2010 | 11:25 PM
My Feedback: (8)
Thanks for the advice!
Randy
Old 05-16-2010 | 11:35 PM
My Feedback: (8)
Who here in the states carries RCexl?
Old 05-16-2010 | 11:38 PM
Just about everyone. but a wise man converting an engine from one type of ignition to another would give Terry or Bill a call at CH electronics. Just send a PM to BCCHI or TKG.
Old 05-16-2010 | 11:44 PM
My Feedback: (8)
I'll do that! Thanks!
Old 05-17-2010 | 11:20 AM
yarom's Avatar
My Feedback: (82)
It's really quite simple - if you are getting no spark when moving the prop quickly over the magnet and looking at a good spark plug, your ignition is not firing. There can be a host of reasons for this - bad battery, switch, bad cable, bad ignition, etc. Generally speaking, 3W ignitions are quite resilient, as they are capable of working with higher voltage than most ignitions.
Before getting a replacement ignition, why not send this one to one of the 3W service providers and see if they can fix it for you? I get very good service and quick turnaround from Aircraft International.
Old 05-17-2010 | 05:51 PM
My Feedback: (8)
I am certain it's not a battery issue. I know we have ample power to the ignition because all the LEDs we have in place to confirm that are in fact doing so.. I'll probably send the two(both of which are pre owned)suspect ignitions in for testing..
Randy
Old 05-18-2010 | 02:55 PM
Carrera_911's Avatar
For the record, I checked the amount of spark my Syssa ignition on my 26GX generates and it is significant and easy to detect in broad daylight any time the magnet passes the Hall sensor (slow or fast). On the other hand, the 3W-106 in question will not generate any spark, or generates an extremely weak spark with a well charged 3900mAh 6 volt pack and properly functioning electrical system otherwise.
The only other thing I can think of, if the problem is not the Hall sensor or the ignition box itself, is that we are on the tail end of using up our 100LL AvGas (LL=Low Lead for those not in the know!) and maybe, just maybe, we are fouling plugs.
I do not agree that 3W ignitions are of inferior design to others on the market. I think we just need to find out why we seem to be having issues where there were none to start.
Thanks for the input everyone!
Respectfully,
Matt
Old 05-18-2010 | 05:22 PM
My Feedback: (20)
Unless I missed something, I don't see the problem defined.. Does it do absolutely nothing when attempting to start? As in no popping, or anything of the like? Does the engine "pop" properly when choked? After removing the choke, does it "pop" again, but not run?
If it's a matter of "popping" and not running, check your throttle butterfly. When closed, you should see the threaded end of the throttle plate retaining screw... Not the slotted head of the screw.. If you're seeing that, the throttle plate is reversed, and it will not draw fuel properly... This is a problem that I experienced, and was driven nearly nutz....
Just my 2 cents worth... I hope you get it solved. BTW, I've been running 3W engines for years, and love them. But hey, that's me...
Old 05-18-2010 | 05:53 PM
They may not be inferior, but with the engines I've used them on they sure haven't had much of a life span. However, I would send it back To Aircraft International. Gerhard is very good about taking care of things 3w.
Old 05-18-2010 | 07:15 PM
My Feedback: (8)
ORIGINAL: johnhere
Unless I missed something, I don't see the problem defined.. Does it do absolutely nothing when attempting to start? As in no popping, or anything of the like? Does the engine ''pop'' properly when choked? After removing the choke, does it ''pop'' again, but not run?
If it's a matter of ''popping'' and not running, check your throttle butterfly. When closed, you should see the threaded end of the throttle plate retaining screw... Not the slotted head of the screw.. If you're seeing that, the throttle plate is reversed, and it will not draw fuel properly... This is a problem that I experienced, and was driven nearly nutz....
We don't get a pop at all when the choke is on!
Randy
