Magnum XLS 52G
RE: Magnum XLS 52G
lexam,
i just came across this thread and was wondering how it's going with this engine ? and if you wouldnt mind answering a few questions for me ?
first, what size tanks are you using to get 14 minutes flight time ?
second, i am thinking about running a pair of these in a H9 B-25 and was wondering if you feel they have the same or more power than the evo NT .36's glow engines ?
and last how much time are you getting with the batterie for the ignitions ?
thanks.
bass
thanks.
bass
CA, AMERICAN SAMOA (USA)
RE: Magnum XLS 52G
I'm running a 6 oz tank. I was getting 28-29 minutes on a 10 oz tank.
This engine has a lot of power. I'm running a 13 X 8 prop and I'm getting something like 9200 RPM. My guess is that would be much more then a .36.
I have never exhausted the battery pack for the ignition in one day yet. I think the most I've ever flown in one day is about 3.25 hours. My guess is most people don't fly this much in one day.
RE: Magnum XLS 52G
ORIGINAL: erieqc
lexam you should have a lot more flight time on this engine by know. How is it going have you replaced the spark plug yet. What voltage are you running to the ignition? Also you probably havent run the engine inverted I was wondering how that would work out along with a pitts style muffler?
Thanks Bill
Thanks Bill
RE: Magnum XLS 52G
lexam,
thanks for the response and answers to my questions. would love to see the video of the engine running.
so if you had to compair this engine to a glow 2 stroke what size would it be ? and also whats the size of the plane your flying it on now IE weight WS type of plane ?
also what is the fuel to oil ratio for this engine ?
thanks
bass
thanks
bass
1 Post
RE: Magnum XLS 52G
This engine definately does exist. My local Magnum distributorhas a few on order and they will be in hand within 6 weeks. I've ordered one
Someone asked whats the point in a small gasoline engine?
Well for one gasoline has a higher energy content per kilogram so theres more power available to convert to thrust.
Some of thepower is absorbedby the extr weight for thancillary kit but the higher torque for bigger props largely overcomes this as does the act hat you can fly a small tank with a lighter fuel and get the same flight time as a methanol plane.
Gasoline is cheaper than Methanol with Nitro, and AvGAS is cheaper still since it does not attract the taxes that road transport fuels attract.
the only issue with runnig avgas is the high tetra ethyl Leadcontent ( a neuro toxin) so how you bahave at the flight field is more important. Actually, methanol with nitro oxidises to form nitric acid which isn';t nice stuff either so there you go, I stillthink ULP is better.
What I am interested in is the octane rating for the engine. Is hte octane required in US Octane numbers which is (RON+MON)?2 or is it in Euro OCtane numbers which is RON?
This is important because a octane sensitivity in the fuel and and MON will be important for good engine life. I may need to tweak my retail site purchased gasoline...
#31
My Feedback: (14)
RE: Magnum XLS 52G
Small two-strokes are not generally very octane sensitive. This is good, considering that the fuel octane is lowered with the addition of lubricating oil anyway. Small cylinder bores below a couple of inches tend not to be octane sensitive.
Ed Cregger
Ed Cregger
#32
MN
RE: Magnum XLS 52G
I will say this....
Isn't part of glow flying the hassle, of flame outs, dead sticks and possible losing a Aircraft over it/??
I have an Os 1.60 twin that is on C&H Ignition, and there is something very satisfying to being able
To walk over to your plane, flip the prop, and know that as long as you have a charged battery, your engine
Will not quit.. The engine runs better, and just Ticks over...
Chachunk, caachunk...
I am looking for a carb, as I would like to get rid of all that Slime on my scale Chipmunk.
I lost a plane this week, due to a muffler pressure issue on a tuned pipe .51 SuperTigre engine...
If I had that Magnum .52G, IT wouldn't have happened!>>>>>
If one is concerned about power on this engine, ADD A TUNED PIPE!....
#34
My Feedback: (16)
RE: Magnum XLS 52G
I was looking at the picture of the Magnum 52 G
It has a pump type carb but is not exactly a Walbro carb.
There is no regulator
I assume that the pump has a mylar diaphragm and the pumping action is weak?
The tank will have to be mounted close to the engine as in glow operation?
How sensitive is the needle valve?
#39
OH
RE: Magnum XLS 52G
If I were going to buy one I was going to put it on a HANGAR 9 Funtana 50 I think that would be a good match except you might have to rethink the fuel tank location. It might have to be moved back a little than again it might be alright were it sets depending on the cg and not wanting to add weight to the tail. I had the Evolution 52 on this plane and had to add a little weight to the nose so it might be alright. Just my 2 cents.
#40
#41
RE: Magnum XLS 52G
These guys VQ Warbirds are expecting to have stock November 10 2010.
http://www.vqwarbirds.com/product_in...roducts_id=130
#42
NY
RE: Magnum XLS 52G
ORIGINAL: rhd-RCU
Great Planes Escapade.
I have a 50 size Enya on there now and the plane has average power.
Fuel is getting too expensive to buy and gas is still cheap.
Anyone know who else makes these 50 range gas engines?
#44
RE: Magnum XLS 52G
ORIGINAL: lexam
#45
RE: Magnum XLS 52G
ORIGINAL: RCer22
#46
1 Post
RE: Magnum XLS 52G
ORIGINAL: w8ye
The carb on this new Magnum is made just like the carb on the Saito FG20 and FG14 gas engines. The Saito carb is a Trouble Magnet
#47
My Feedback: (14)
RE: Magnum XLS 52G
ORIGINAL: RCer22
I am thinking of getting one for my Escapade.
ORIGINAL: rhd-RCU
If your Escapade isn't well powered by a glow Enya .50, your Magnum .52 gasser is going to be very disappointing, power wise.
Now if you were currently powering your Escapade with a sporty .32 two-stroke, THEN you might attain parity with the Magnum gasser.
Ed Cregger
#49
My Feedback: (14)
RE: Magnum XLS 52G
ORIGINAL: TimBle
You have flwon this engine in order to be so authoritive about its performance?
No, but I have enough knowledge about the difference in power that gasoline fuel provides versus glow fuel to know that parity between the two is physically impossible. Does your physician have to have experienced lung cancer in order for him to diagnose a patient with having lung cancer? Same thing.
Ed Cregger
