90 Degree Carb Manifold for Zenoahs
AL
I know Toni Clark makes a 90 degree intake for Zenoah engines but the weaker dollar and shipping make them somewhat prohibitive.
Why hasn't a US distributor, someone like B&B made these availible?
Do they diminish the performance of the engines at all?
RE: 90 Degree Carb Manifold for Zenoahs
90 degree intake=copper water line elboe...silver solder a flate flange at each end. T. Clark mentioned how to do it. Capt,n
AL
ORIGINAL: captinjohn
My Feedback: (9)
WA
These guys have been advertising here on RCU. They carry the Toni Clark stuff, and seem reasonably priced.
Sam
[link=http://www.vogelsangaeroscale.com/]Vogelsang Aeroscale[/link]
Sam
DC
George Vogelsang won every QSAA event he ever flew in..He always brought spectacular airplanes, once brought two pulse jets capable of 300+ mph..A GIANT WW1 bipe powered by a 250cc ultralight twin, with sound effects for machine guns..Always wondered what happened to him...He was/is a German industrialist, said he had a factory on our east coast along with his Geman factories...Sold him a converted G62 at a QSAA once...
The cast 90 degree mount looks nice; sure wish I knew how to cast aluminum.
As far as the copper elbow, three thoughts:
1. When they made it/brazed it up, why not braze the brass pulse tube in place at the same time instead of gluing it on with JB Weld?
2. Why use a pulse tube at all when an exterior pulse setup is so easy to do?
3. One should really use a spacer of some sort that won't transmit heat to the carb with that elbow.
AV8TOR
AV8TOR
AL
Like Ralph said, those flanges look mighty thin. I have access to a waterjet so I would just cut my own out of 3/16 aluminum the put them together with Dura-Fix.
Is 7mm too thin for an insulator block?
My Feedback: (264)
MD
I have two of the Toni-clark G-62 manifolds and the beauty is that although they fit tightly against the engine, the gas passage design is sort of like a corkscrew and there are no tight radius turns in there.
IMO, a copper pipe and elbow design is never going to work as well.
Someone will just need to cast a copy of the TC manifold.
