crrc timing?
Old 06-30-2010 | 01:32 PM
Default crrc timing?
hey guys i have a crrc pro gf26i v2. and can any one tell me what the actual timing is on this motor. the reason why im asking is when im trying to start it , it trys to start but kicks back and foreward and then stops. it has about 4 hours run time but no air mileage yet because it tends to vibrate too much when i throttle up at first, but then it smooths out. i think i measured the timing properly and its at about 38-40 degrees. i used the rcexel timing kit for that. i have moved it a little to the left and right but not much difference.
any ideas?.
Old 06-30-2010 | 01:51 PM
Piston's Avatar
Default RE: crrc timing?
Hey Colin
The timing should be @28 degrees..... A lot of the asian engine shops put their timing waaaaaay ahead.. why? They can claim a more rpm...at the expense of mid range and start up. Its a cheap trick.
You want a faster way to check the timing, adjust it and make it right on???
[link=http://www.rcaer.com/userfiles/file/RC%20Aero%20-%20Timing%20your%20Engine.pdf]Timing your engine the easy way.[/link]
I wrote this article a while back. It is one of the most popular downloads on my site.
Cheers
Henry
Old 06-30-2010 | 02:29 PM
w8ye's Avatar
My Feedback: (16)
Some of the CRRC engines need the timing bracket modified to get the timing down to 28 degrees
Old 06-30-2010 | 02:31 PM
ggraham500's Avatar
Timing looks easy and best of all uncomplicated to determine or adjust. Great. Thanks!
Old 06-30-2010 | 02:56 PM
ggraham500's Avatar
ORIGINAL: w8ye
How so? Can you explain more, please?
Old 06-30-2010 | 03:04 PM
thanks henry ,your a life saver!.
Old 06-30-2010 | 03:06 PM
Old 07-01-2010 | 08:10 AM
I had an SV50 with the same problem. I had to elongate the slots in the bracket with a moto tool or file to get to 28deg. I also had to use a larger washer on one end because I cut the slot all the way out. If that doesn't work, a radiator hose clamp will let you set the timing wherever you wish. The hose clamp is what C-H ignitions sends with their universal ignition set. Works fine.
