Prop Question
OH
I have a GP Sukhoi SU-31 with a RCGF 50 CC engine. I love the way it flies. I have a 22x10 APC prop on it now and have about 1/2" ground clearance. I am putting on a 20x10 prop which will give me another 1". Is that to small of a prop for a 50 cc engine?
Go to TNT and have them make a taller set of gear. They have a printable form on the web site that you fill out for custom gear. Get your numbers written down. Then call and give them the A-B-C-D measurements. They have way better metal than stock gear. Prices are about the same as two broken props. I have a 33% H9 Cap that is 2in. higher than stock.
I have the same plane with a DLE 55 on it and went through the same thing. I have since decided to put a 45cc on it.
Before that I was considering putting longer landing gear because that seemed to be the best option.
A three blade will absorb some of the power but you have a ton to give. As for over reving with a 20x10, believe me you will only be using about 1/3-1/2 of the engine's power in 3-D flight anyway.
