DLE 20cc Gasser! (Data & Links 1st Post)
#1826
My Feedback: (7)
IN
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
P-40K-5,
I looked over your build thread and I'm impressed with your attention to detail.
Very nice model!
This DLE20cc gasser looks like it belongs in that model!
Very nice model!
#1829
AR
I am starting to get concerned about my DLE 20 now , i dont have a warbird to put it on, would it do ok on a fun fly sport type model? it had unlimited vertical with a saito 150. so i am guessing i wont lose much performance if any,
#1831
Go mine running this afternoon and it is strong as mule piss! I tried a Vess 16x8 (8400) and 17x6 (8200) sport. Can't wait to fly my Aeroworks Edge 540T next weekend!
#1832
ORIGINAL: bcchi
Thanks John,too much trouble to make them. I found some that will work. I couold make them but to tired.Looks like we are finally going to have a little winter. Did not get to fly today and tomorrow looks worse.
I have run Dl 30 with fixed timing runs fine idle is not as smooth of course.Not big enought to hurt you with kick back.We run all of the weedie engines for years with fixed timing about 26To28 BTDC.
Dl 20 flies the 90 U-CAN-DO fine.Just does not pull out of a hover as good as the 30.Only got one flight,weather turned crappy.
BCCHI
ORIGINAL: captinjohn
BCCI, I can make you a set of round stand-offs for you 20cc engine on my lathe. Give me a length & dia. I can do them for free....if they are not too complicated. Capt,n
BCCHI
Capt,n
#1834
My Feedback: (7)
IN
This is the "New DLE20cc Gasser!" thread. Shouldn't that belong over in the "NEW DLE30! message thread" ?
For others reading here; the DLE20CC is a rail mount gas engine (std glow engine style mounting), which does NOT use "stand-offs".
#1835
My Feedback: (7)
IN
Jody,
I see VVRC is listing some "Carbon Fiber looking Propellers"
Are those basically wood props with some sort of coating?
Any thrust figures for a 17 x 8 on this DLE20cc?
#1836
G'day....for info...I fly a CMP J3 Cub....(2032 - 91") - fitted with a CRRC 26cc petrol. Definitly too much power.....but....its looks like I must have a soft touch on the throttle??
Regards,
Tony
Regards,
Tony
#1837
ORIGINAL: a1pcfixer
Jody,
Jody,
#1838
My Feedback: (7)
IN
Jody,
They are indeed cool looking props. Thanks.
Another question; the chrome prop nut, is it the ONLY thing
holding a prop on this DLE20cc, or are the double nuts hidden
underneath it?
underneath it?
#1839
My Feedback: (7)
IN
ORIGINAL: aidalry
G'day....for info...I fly a CMP J3 Cub....(2032 - 91'') - fitted with a CRRC 26cc petrol. Definitly too much power.....but....its looks like I must have a soft touch on the throttle??
Regards,
Tony
Regards,
Tony
You might be better off with a JBA .15 instead.
[link=http://www.rcuniverse.com/forum/fb.asp?m=10141136]DLE20cc details & info......[/link]
Note: [Interesting Comments]
#1840
ORIGINAL: a1pcfixer
Jody,
underneath it?
Jody,
underneath it?
#1841
My Feedback: (7)
IN
ORIGINAL: jedijody
Is there a picture of the DLE20 you are talking about, is it on our site?
#1842
CA
ORIGINAL: jedijody
They're glass filled nylon and are copies of APC propellers with a cool carbon like paint job, I don't know how they do it. They are the 16x8 and 17x8 props I post numbers on at the beginning of this thread. They've been tested against APC props several times and are as identical as it gets.
ORIGINAL: a1pcfixer
Jody,
I see VVRC is listing some ''Carbon Fiber looking Propellers''
Jody,
#1843
My Feedback: (7)
IN
ORIGINAL: mesaflyer
I guess I know what prop my wife will need to order when she orders the engine!
You can also toss in one of those Alum spinner nuts as well.[sm=lol.gif]
Sure hope the stock double nuts fit beneath that one.
#1844
Hi Jody
this probly been asked and answered else where in this thread. But at 74+ pages Im not going to look for it.
Whats the all up weight, wing span of that profile you got the DLE20 on.
Randy
Randy
#1845
ORIGINAL: a1pcfixer
[link=http://www.valleyviewrc.com/DLE-20cc%20Gas%20Engine.htm]Polished alum prop hub.....[/link]
ORIGINAL: jedijody
#1846
ORIGINAL: RadioPhlyer
Hi Jody
Randy
Hi Jody
Randy
#1847
My Feedback: (7)
IN
ORIGINAL: jedijody
Yes, that hub serves as the prop nut the OEM nuts and washer is not used.
#1848
Why not? It can't get looser, if it slips it just gets tighter. If you stick some adhesive backed sand paper on the hub face it can't slip. Many, many, engines in scale applications have used the same system for decades without problem.
#1849
I was really more interested in the stats on the aircraft. Than the aircraft it self. The performance is good ,, but not stellar. No doubt it would do better on a lighter ship. I'd like to see it on a profile designed around a 120 gasser. But it is a good test bed for the motor. Gives a good idea what its capable of.
The smaller 2 stroke gassers run just like they do on power equipment. Most small engines like this only run in 2 conditions wide open or idling, not much in between and the carb operation reflects that. And they are never broke in. Most are gassed up and run wide open from the time they are purchased till they get thown in the dumpster hunderd of hours later.
Thanks for the info.
Randy
Randy
#1850
CA
ORIGINAL: a1pcfixer
Make two DLE20cc & two 17 x 8 CF looking props......one for you, one for me!
ORIGINAL: mesaflyer
Just need one more nail in that stocking on your mantle!
BTW, my wife thought that was pretty funny. Unfortunately, she wont' be sending you an engine[&o], but still funny.
