Thrust
TX
Does anyone know the formula for a ballpark calculation of engine thrust?
Say your armed with manufacturers info: H.P., rpm range, recommended prop sizes. We assume the "little" things; engine broke in, carb tuned correctly, stock muffler, good fuel mixture, etc. ...or are there just too many variables, and bench-testing the only reliable source?
Calculting thrust seems like it would be very helpful in engine selection.
thanks,
Bryan
thanks,
Bryan
I use it the other way around. Have prop and rpm, then calculate power and thrust. Usable data can be obtained from the many discussion groups. You soon find out which manufacturers lie, and which don't.
You can use any combination or approachthough in a simplified set calculators when you scroll down on the main page. The obtained power and thrust figures have been wind tunnel tested by CA students, and were found to be within 5% on the low side.
ThrustCalc is up to 30% off (too high)
