RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   prop type for 30cc gas engine (https://www.rcuniverse.com/forum/gas-engines-142/10524688-prop-type-30cc-gas-engine.html)
selnekav 05-16-2011 11:05 PM
Hi,
What is the preferred type of prop ? wood, CF, APC
scooterinvegas 05-16-2011 11:20 PM
RE: prop type for 30cc gas engine
I run Vess and Xoar 18x8 - 19x6 wood on mine.
w8ye 05-16-2011 11:26 PM
+1 on the Xoar and Vess
selnekav 05-16-2011 11:54 PM
i forgot to mention that i need it for pattern plan ( Zen 120 + SAP 180 )
selnekav 05-16-2011 11:57 PM
I thought about wood prop because it weight less. is wooden prop produce less vibrations then APC ?
ahicks 05-17-2011 03:34 AM
I run APC. The durability and consistency they offer sport flying off a grass field outweigh any drawbacks for me, but that's just my call. The concern running them (or any composite prop) is that they could potentially bend the crank in the case of an accident. That potential, balanced against the fact wood props seldom have grass stains on them without breaking, is a risk I willingly take on. I haven't bent a crank using one - unless you want to count the time the cylinder broke off the crankcase as well. As you point out, they are heavier. Some will say they're sharp. That can be easily handled with some sandpaper while balancing. If you have a sharp APC it's because the prop wasn't prepared properly IMHO.
kmeyers 05-17-2011 03:55 AM
ORIGINAL: selnekav
I'm thinking in a similar application about a Xoar 18 x 10 laminated. Light, strong and high speed.
You can try it first and let me now.
AJsToyz 05-17-2011 04:07 AM
If your doing actual pattern flying check this thread.
http://www.rcuniverse.com/forum/m_92...58/key_/tm.htm
selnekav 05-17-2011 05:53 AM
i think 18 x 10 will be overprop for the SAP on standard muffler
