Nitro Gasoline Conversion
Dear All,
With the introduction of small spark plugs i.e. 1/4-32 size (same as nitro glow plugs thread) the nitro to gasoline conversions is growing rapidly each day. A simple placement of magnet, pick-up sensor and off course the ignition unit, you are basically set to go... In this video, even though it shows a heli, but in it was the thunder tiger 70 nitro however it was modded with all the mentioned items above. It runs on 95 octane gasoline fuel with 30 to 1 mix of 2 cycle mineral oil. But most importantly, do not ever repeat what is being shown in the video. It is a dangerous move even for a professional or anybody for that matter. And that is my main intention of posting this thread, please never ever do this. I was surprised myself!!!! [youtube]http://www.youtube.com/watch?v=wyoQgp6bU5c[/youtube] The spoken language is Bahasa Malaysia, but i guessed international forumers may get the idea what i was talking about based on my voice intonation. |
RE: Nitro Gasoline Conversion
a few pointers.....
first off ,definiteley a very stupid thing to do.......... a minor detail... this heli looks like a raptor 60 to me (not 50), this one had the tt-70 pro pre-installed (won't fit the 50). also the frame on the 50 is made of plastic. 30:1 gas/oil ratio without a needle bearing on the crankshaft/conrod is a bit too less i think. without the bearing i think the same oil content as glow fuel should be used. that is around 18% oil. it sounds like a tad too rich on the lower rpms. maybe a walbro carb would do the trick. |
I totally agree, a real foolish thing to do.
Karol |
foolish or not, I am not to judge.
If glow needs 18% oil, gas can do with a lot less because gas itself is a lubricant and methanol is not. 7% (1:15) to 10% (1:10) would be about right for bronze bushed connecting rods. The engine in the movie still was running very rich, so would get enough oil. Things change when leaned out properly and under full working load. |
Thanks for the insides on the oil ratio... and off course i corrected the heli model. I don't own raptor heli.
No matter how confident one can be with it's equipment, all it takes is just a very minor mechanical or electronic fault, the whole thing might slammed itself to the flier. it is just too dangerous. |
Forgive me... I didn't watch the vid....
but what is so "foolish" or "stupid" about converting an engine? |
I have been doing several engine conversions here and I tell the owners to use a 16-1- 20-1 ratio depending on which engine is it.
Watching that vid show what little respect the flyer has for the equipment and I expect if that sort of thing continues he will learn a lesson the hard way. |
OK...watched....
yes.. his handling of the Heli is one of the more... Darwinian things I have seen.... is that what the comments were for or was it for the conversion itself.... |
On another note about converting to electronic ignition is you can run E85 and mix caster with it and your fuel cost would be about $8.00 a gallon, Plus you can still tune and run it with your glow carb.
Milton |
With e85 you would need a lot more oil, and have the same mess as a glow engine.
ORIGINAL: pe reivers With e85 you would need a lot more oil, and have the same mess as a glow engine. Milton |
Milton
With E85 would you need the Electronic Ignition? |
all in what size engine you are running, If you do not need nitro in your fuel it will work. just like the large supper tigers did not need nitro. forget what the glow fuel was called with no nitro in it.
Milton |
FAI?
ORIGINAL: BadAzzMaxx On another note about converting to electronic ignition is you can run E85 and mix caster with it and your fuel cost would be about $8.00 a gallon, Plus you can still tune and run it with your glow carb. Milton |
ORIGINAL: pe reivers With e85 you would need a lot more oil, and have the same mess as a glow engine. |
1 Attachment(s)
I have found that only the glow carbs with a very fine thread on the needles can be used with gas, other wise a person has a very tough time finding the correct tune.
I just finished up a Saito 270 twin where I used the glow carb and so far it seems to be working ok, but I think a walbro would have been better. At a 16-1 - 20-1 ratio the clean up is no where near that of what 18-20 % oil is in glow fuel. Making an adapter for a walbro type carb has proven to be the best route to go and so far I have not had and issues finding a suitable carb for the conversions I have done. Here are a coupls of pics, one is a 160 FX and the other is a 160 FT twin. There was not enough room for the carb on the twin to lay down so I turned it up right, something like the larger gas engines are. Both engine's run great and are able to swing the larger end props W/O the lag they had on glow fuel. Both are on 20 -1 gas oil mix |
ORIGINAL: Cyberwolf I have found that only the glow carbs with a very fine thread on the needles can be used with gas, other wise a person has a very tough time finding the correct tune. I just finished up a Saito 270 twin where I used the glow carb and so far it seems to be working ok, but I think a walbro would have been better. At a 16-1 - 20-1 ratio the clean up is no where near that of what 18-20 % oil is in glow fuel. Making an adapter for a walbro type carb has proven to be the best route to go and so far I have not had and issues finding a suitable carb for the conversions I have done. Here are a coupls of pics, one is a 160 FX and the other is a 160 FT twin. There was not enough room for the carb on the twin to lay down so I turned it up right, something like the larger gas engines are. Both engine's run great and are able to swing the larger end props W/O the lag they had on glow fuel. Both are on 20 -1 gas oil mix The highlighted notes is superb! It is true to the essence! |
John,
I am a ship's engineer by original profession, and used to crawl front to back through those hot oily contraptions they call engines for inspections. Nowadays, whenever I can get by without oil all over me, I will choose that option. My gas planes stay clean after the first running in period. I just love that, and it is not laziness I can assure you. The plane too is not jeopardized by oil seepage into the wood and nooks and crannies, or cover seams (I hate cover). For that reason I use an air filter on my engines whenever possible, so all blowback is eliminated. I would however never use less oil than the percentage needed by the engine just to save me some cleaning. For that reason, my standard oil mix is 3% (1:33) for hard working glider tow engines, and 2.5% (1:40) for loafing around. |
ORIGINAL: Cyberwolf I have found that only the glow carbs with a very fine thread on the needles can be used with gas, other wise a person has a very tough time finding the correct tune. I just finished up a Saito 270 twin where I used the glow carb and so far it seems to be working ok, but I think a walbro would have been better. At a 16-1 - 20-1 ratio the clean up is no where near that of what 18-20 % oil is in glow fuel. Making an adapter for a walbro type carb has proven to be the best route to go and so far I have not had and issues finding a suitable carb for the conversions I have done. Here are a coupls of pics, one is a 160 FX and the other is a 160 FT twin. There was not enough room for the carb on the twin to lay down so I turned it up right, something like the larger gas engines are. Both engine's run great and are able to swing the larger end props W/O the lag they had on glow fuel. Both are on 20 -1 gas oil mix |
The 270/300 twins can use the same carb as the 150/180 singles because the cylinders fire alternately on this twin four stroke..
Hi errie
The OS 160 FX has a Walbro WT-499 The OS 160 Twin Gemini has a Walbro WT-400 |
The 499 is the stock carb on the not now sold Zenoah G23 glow version...
Its also the stock carb for the Evo 26
Cyberwolf,
Would love to see more photos of the 160 twin carb setup. I just got one and plan on a gas conversion as well. How did you plumb the carb pump pulse? I assume the crank case vent using a "T"but that's just an assumption. Looks great though, I need to machine a manifold and would love to see more photo's of yours if you have them. Thanks, |
1 Attachment(s)
Maybe the best way is to get the hollow bolt with a fuel barb on it and go thru one of the top holes in the back plate. I went thru the side mount lug on mine which worked out good for me , I recessed it in case of a crash it won't get busted off.
Sorry these are all the pics I took of it. |
Cyberwolf do you have any video of the 160 FX in flight ? what's about the power compared to the glow engine version ?
how do you know the WT-499 is the best / suitable carb for that engine, did you try any other carb ? |
Sorry, I was talking about theFT twin. Did you use a "T" from the crank case vent? How dificult was the manifold?
Thanks, |
1 Attachment(s)
Hi Yes I split the vent line for double duty as the pulse and still vents, seem to work fine. I figured the area of the glow carb and the WT-499 although larger seem to fit the bill ok, A person might can go a tad smaller throat Dia and still have good Top RPM's, you need to remember your only feeding an 80 size engine per stroke, or even a carb with a accelerator pump I am told works good. I myself didn't see the need of it but some do.
The manifold was not hard to do with the help of a lthe and milling machine, you can see if the pics I turned the exsisting manifold 90 degrees and made a retsiner to rebolt things back into place to hold it all together. |
Thanks for the information!
| All times are GMT -8. The time now is 11:03 AM. |
