DA60
Ihave an aeroworks edge 540 powered by a DA60 Iam using a EQ6 smartfly with a DX7 radio and my throttle servo glitch only in flight it will not do it on the ground Ihave changed the throttleservoand the receiver relocated the ing wire and put a data logger on it and it shows nothing if any body has any ideas let me know thanks
Paul |
RE: DA60
how far away is the throttle servo from the ignition. I had that problem once, possibly might have just been the Fuji ignition. just a thaught
RE: DA60
would help if you post pictures of your set up. had a pproblem where my throttle servo would glitch on the ground at lower rpms(servo wasinstalled at the bottom of engine box with ignition module at the top). relocated theservo back into the airframe just ahead of where the elevator servors are located and no more glitching.
RE: DA60
ORIGINAL: Smallpaul01 I have an aeroworks edge 540 powered by a DA60 Iam using a EQ6 smartfly with a DX7 radio and my throttle servo glitch only in flight it will not do it on the ground I have changed the throttle servo and the receiver relocated the ing wire and put a data logger on it and it shows nothing if any body has any ideas let me know thanks Paul |
RE: DA60
have you tried a different channel?
ie: plug the ail servo into the throttle channel... does anything happen? cna you plug the throttle servo in to a different channel? |
RE: DA60
I have tryed different channels on the smart fly and it does the samething I have also called bob at smart fly he told me to move the ing. wire so I did and it didnt fix it the throttle servo will work fine when plane is on the ground like I said I have also put a data logger on it and it doesnt show anything the scary part is it only acts up when I get about 2 minutes into the flight the throttle servo starts to act up
RE: DA60
hmmm...what exactly is happening?
You say it is a throttle servo glitch, and it only happens in the air? |
RE: DA60
yea the throttle servo starts to glitch after I do about 2 laps around the field you can hear the engine go from 1/2 to 1/4 to wide open I only got it to glitch once on the ground I then changed throttle servo and now it only glitchs when flying
RE: DA60
What happens if you don't power the servo through the power expander? Have you checked the security of the spark plug cap? Have you checked the switch connections? Have you checked the condition of the battery leads? What kind of linkage connections are you using? Metal to metal at the carb end? How about at the servo end?
The servo obviously was not the problem. |
RE: DA60
I have used this throttle servo in a different plane and it works just fine have also checked all batt connections and all smart-fly connections I have even moved my satlelight recver away from the smart-fly I have a plastic ball link on my carb linkage and the same on the servo with a plastic servo arm have also checked the serurity of the spark plug cap and its tight
RE: DA60
I'll bet your throttle is going into failsafe due to the ignition swamping the RX. I had the same symptoms on 2 GS planes with DA 85's and spektrum equipment.
You probably bound the plane with the throttle position at low throttle, correct? In my case I was also blaming the throttle servo because I didn't realize I was briefly losing control (of the entire plane) but the most obvious symptom was the throttle servo would attempt to go back to idle (my failsafe position). All other channels should hold last known position. I verified the issue by doing range checks on the ground with and without the engine running. Two different RXs and two different TX's were used in my case, which helped me narrow down the problem to my ignition noise. Initially, I swapped the throttle servo, but of course in my case it didn't help either. As others have said, check your grounding on the spark plug. I suspect it's worn or you may have other IGN issues. You can verify my theory by doing range checks with and without the motor running (on the ground). Joe |
RE: DA60
I have done range checks on the ground with the plane running and not running with a data logger on it and it shows nothing one test I did do was I had my buddy hold the plane with it running and I walking a good 1/4 mile away and the throttle servo was working fine but once I take off and do about 2 laps around it starts to act up I will check my spark plug cap again but everything in my plane is new the engine is not even broke in yet </p> |
RE: DA60
Are the lights flashing on the RX indicating a reboot? would a momentary reboot kill the ignition causing a deadstick?
RE: DA60
no the lights are not flashing on the RX I have done alot of dead stick with the plane because of the servo glitch so when I get about 100 feet of the deck I kill the engine and land the plane
RE: DA60
if it doesnt do that on the ground and does in the air then the only thing different is air speed.
air pressure in the cowl could be pulsating and causing the plug boot to be intermittent??? causing RFI??? is the servo strong enough for the application, do you have spring on throttle, is the pushrod stiff or flexable? |
RE: DA60
yea the servo should be strong enough its a hitec 5645 and its a metal push rod with plastic ball links on each end Iam really thinking its the spark plug cap so I will just order a nother one from DA
RE: DA60
The other difference between in the air and on the ground is that the receiver may not see the radio signal. Are the receivers (dual one?) installed properly? In particular, the antennas?
| All times are GMT -8. The time now is 04:45 AM. |
