Questions Regarding Older Zenoah Engine
1 Attachment(s)
Hi guys, I need some help with figuring out modification on a Zenoah 3.70 cu in Quartz I got from someone who didn't know what type modification it was, anyway here are some photos of the engine, can somebody explain what the modification is, Kill switch or ignition?;)
RE: Questions Regarding Older Zenoah Engine
Whats that red plug for???;)
That is a Ralph Cunningham G62 light conversion, you will not find a better engine anywhere than that one.
The plug on the side of the cup mount is for the power to the ignition. Milton |
Can I get an after market Ignition for it BadAzzMaxx? I think I struck gold here, this engine has so much compression it wants to wring my wrist whenever I turn the prop shaft, very good engine, yes sir.
Yes, But is the ignition on it not working.
Milton |
I did not get one with the engine.
Ralph is called Antique here on the forums, If you have a problem with that engine I would contact him, He knows that engine inside out.
I do replacement carry ignitions if you want to go that route. Milton |
That is it you are looking at in the cup mount, Just get a connecter that fits the red plug on the side and it should work.
Milton |
Is CH ignitions still in business, where can I find one???
Ok I got that, if I get the plug where would I attach it or what would I attach it to??
No CH has closed for now, But again, Hook up a battery to the red connector on the side of the cup.
The ignition uses the existing Zenoah coil and the electronic board in the cup mount is what fires it. Milton |
I see that you sell replacement Ignitions, cool, do you sell any for this engine??
Ok BadAzzMaxx, this is very helpful information, I will try what you've just recommended.
Why do you want to buy a ignition when you have one that should work. To use my ignitions you have to remove the one in the cup mount, Remove the existing coil and then install a connector to the sensor lead wire. Milton |
Pardon me BadAzz Maxx, I wasn't sure what the circuit was, but I will hook up a battery pak, is 4.8v pack fine to use??
Yes
ORIGINAL: mustangshooter I did not get one with the engine. Unless I'm badly mistaken that's the ignition inside the cup mount at the rear of the engine. Karol |
First time seeing such a setup Karol.
Back then it was one of the best setups you could ever get. Still is too, including the engine conversion.
Karol |
It's one of my old conversions...If the ightion doesn't work send it to me, it's guaranteed...
BOY! You can not beat that!!!!!!!
Ralph is de best.
Karol |
yup....echo that Karol :)
See why people love Ralph so much?
Very neat idea, when I first got the engiine I was uncertain what the heck the setup was, was it a kill switch or ignition, found out all about here on RCU, thanks alot guys, all inputs were quite helpful.
