DLE 111
Does anyone know if you can reverse the rotation on this engine to use it as a pusher ? I cant find much info on it , I have read small amounts but nothing concreate
RE: DLE 111
Yes, it can run opposite direction. Just reset the pick-up to be timed at the 28-30 in the opposite direction.
RE: DLE 111
Thanks man, Do you know the how abouts of doing it ?
RE: DLE 111
The simpliest way would be to buy a strap on pick-up. There's one here, just scroll down a little 11.95 universal timing clamp. http://www.rcextremepower.net/ignitions.html
RE: DLE 111
Where ya flyin at over there?</p> |
RE: DLE 111
1 Attachment(s)
Any reason for not using a pusher prop from Zinger? That's what I did on this 50cc pusher. The brison 3.2 runs great this way. Dan.
RE: DLE 111
Not flying< its for an RC Airboat. I just figured I could get more answers from the Plane guys...lol I'm looking for a beast of an engine. one that will push a 55 x 30 inch hull
RE: DLE 111
There is not a large selection of props in the pusher catagory. I would just rather reverse the rotation so I would have a better selection. Zinger only makes wood props, Right ? They dont do well when they come in contact with water...lol
RE: DLE 111
ORIGINAL: jetG23 Does anyone know if you can reverse the rotation on this engine to use it as a pusher ? I cant find much info on it , I have read small amounts but nothing concreate |
RE: DLE 111
tande. Not one for argueing but how do you come to that conclusion. My understanding is it's just an open port.
RE: DLE 111
ORIGINAL: acerc tande. Not one for argueing but how do you come to that conclusion. My understanding is it's just an open port. Menz make pusher props in most sizes. I bought a matched pair from Menz for the two counter rotating G62 in my Cessna 421 |
RE: DLE 111
1 Attachment(s)
ORIGINAL: acerc tande. Not one for argueing but how do you come to that conclusion. My understanding is it's just an open port. |
RE: DLE 111
A picture is sometimes worth a thousand words.
Karol |
RE: DLE 111
1 Attachment(s)
ORIGINAL: karolh A picture is sometimes worth a thousand words. Karol Yes, even the "Reed/Block" is "Directional"..... |
RE: DLE 111
The offset mean's nothing other than it's offset. ALL reed block's are directional, just not as it regards to crank rotation. End of subject for me!!!!</p> |
RE: DLE 111
ORIGINAL: tande ORIGINAL: jetG23 Does anyone know if you can reverse the rotation on this engine to use it as a pusher ? I cant find much info on it , I have read small amounts but nothing concreate I have. jetG23, Buy the universal positionsensor,set the timing at 28* BTDC,put the prop on backward and give it try, you may be surprised. |
RE: DLE 111
Cool man, thanks !!! I dont have the engine yet. I didnt want to jump into it without knowing if it would run opposite.. it ought to make one heck of an Airboat engine !!
ORIGINAL: jedijod ORIGINAL: tande ORIGINAL: jetG23 Does anyone know if you can reverse the rotation on this engine to use it as a pusher ? I cant find much info on it , I have read small amounts but nothing concreate I have. jetG23, Buy the universal positionsensor,set the timing at 28* BTDC,put the prop on backward and give it try, you may be surprised. |
RE: DLE 111
Thanks for all the input guys !! I'm also looking at the DLE 170 witch to myunderstanding is not directional in the case .....
| All times are GMT -8. The time now is 09:07 AM. |
