RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DLE Spark plug, wire & cap (https://www.rcuniverse.com/forum/gas-engines-142/11145163-dle-spark-plug-wire-cap.html)
dasintex 07-06-2012 06:10 AM
New to Gas and DLE Engines; I changed the original Un-Marked Spark Plug with a NGK CM-6; I had to use a lot of effort and force to push the metal shielded Spark Plug Boot solidly onto the Spark Plug, is this normal? Also, my engine came with a Spring which I'm presuming goes inside the Spark Plug Boot, does the spring help ground the plug, and is it needed?
Thanks.
JRgraham 07-06-2012 06:34 AM
RE: DLE Spark plug, wire & cap
Yes its normal to have a snug fit on the spark plug boot. The spring is not needed. It is meant to place inside the plug cap.. Irun all mine without the spring, and everyone else Iknow also toss's them asside.
STUKA BARRY 07-06-2012 06:42 AM
Those sparkplug caps can sometimes be a real bear to get on and off. There is a cerclip at the bottom of the cap that spreads apart over the hex on the sparkplug itself, this is normal.
dasintex 07-06-2012 06:44 AM
'STUKA BARRY'; do you go along with 'Shimano' in regards with the 'Spring'?
Truckracer 07-06-2012 06:57 AM
I'm not Stuka Barry but I certainly agree regarding the spring. The cap makes a very good ground connection by itself ... spring not needed if the cap is all the way on the plug. When fully installed, the cap will fully cover the hex part of the plug.
dasintex 07-06-2012 07:14 AM
Hey Guys, thanks for the help, I had fully seated that Plug Boot down and noticed the 'Spring' laying on the floor, and I wasn't looking forward to removing it now to put the spring back in.
raptureboy 07-06-2012 09:50 AM
+3 3 dle's no springs no problems
captinjohn 07-06-2012 12:31 PM
Use a 1/4 wide geared hose clamp. Makes for easy on &off...
they do not slip off. Just check the screw on clamp once in a while.http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif
karolh 07-06-2012 06:02 PM
Here's a tip to help you get the cap on all the way and also for getting it off, just give the cap a half turn and push to get it fully seated on the plug, and similarly a half turn and a pull to get it off.
Karol
captinjohn 07-06-2012 08:00 PM
Yes that is the way. When you turn the cap the Hex on the sparkplug acts like a ramp to expand the cap so that it will go in place more easy. Watch close when you do it and you will see and actually feel how this happens. No rocket sicence....heck any Old timer on here could tell ya that ! http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif</p>
karolh 07-07-2012 09:43 AM
Capt,n,
I guess at my age I should qualify as an old timer, now wether that is good or bad that's another matter :)
Karol
basimpsn 07-07-2012 09:56 AM
I just bought a new dle 111 engine and ran about 1gal thru this engine with the stock plug without any problem. My question is, if the stock plugs working ok why change it ?? Is there something wrong with the stock plugs? what am I missing here??.
P.S new to twin engine
Thanks guys
karolh 07-07-2012 10:22 AM
Some work but most don't so consider yourself among the lucky few, just make sure you have a CM-6 replacement on hand for when the stock ones craps out.
Karol
basimpsn 07-07-2012 12:10 PM
ORIGINAL: karolh
Karol
Ok
dasintex 07-07-2012 12:21 PM
I changed mine because it came loose on the first run breaking in 1 gal of gas, talked to someone else and they said the Plugs come loose caused a few deadstiks, talked to yet another person, and he said it was well documented on another RC website that the OEM DLE Plugs come loose, that the compression washers fail, that everyone changes them out for the NKG CM-6; that was evidence enough for me to do the same, I will say, the engine ran great with the DLE Plug, except it came loose.
basimpsn 07-07-2012 07:00 PM
ORIGINAL: dasintex
Well.. I did notice how loose my plug were out the box. So that could be the reason why others was having problem with loose plugs.
ahicks 07-08-2012 04:24 AM
ORIGINAL: basimpsn
Thanks guys
My answer would be because of the well known high failure rate, and just as well known cause of erratic running? I agree with you though. If they're working and you aren't having issues, run em! But do have spares handy....
basimpsn 07-08-2012 05:34 AM
ORIGINAL: ahicks
ORIGINAL: basimpsn
Thanks guys
Thanks guys point well taken, I guess my phobia started when (In the past) I replace a working spark plug for a better plug on my ZDZ 80 engine and end up with a close call dead stick and a strip out cylinder head. Not saying is the plug fault, just want to make sure the stock plug is not falling apart inside the cylinder;).
karolh 07-08-2012 07:51 AM
Most times stripped spark plug cylinder threads is caused from dumb thumbs. One thing to remember is never attempt to remove a plug from a hot engine as in doing so you are asking for trouble.
Karol
basimpsn 07-08-2012 11:21 AM
ORIGINAL: karolh
Karol
Hey Karoth how is things in cool Mandeville? hope to visit your field sometime.
karolh 07-08-2012 05:33 PM
It's been very wet and windy these last couple of weeks but otherwise we are good. Would love to have you visit anytime you are in the neighbourhood.
Karol
grossy2 07-08-2012 08:18 PM
Can anybody tell me the spec's of the resistor that's in the cap for a CM-6 plug?
Cheers
bcchi 07-08-2012 10:16 PM
ORIGINAL: grossy2
Cheers
I-K 1 W
BCCHI
