RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   what engine is this? (https://www.rcuniverse.com/forum/gas-engines-142/11164924-what-engine.html)
warbirdav8r 07-22-2012 03:52 PM
1 Attachment(s)
I aquired this from a friend. Don't know much about it. Looks like at least 75cc but dont know what brand etc.. Has Ralphs ign. on it I believe. Also does anybody know if the center pin on this speaker jack type of plug for the Ign.battery is pos. or neg? Any info is helpful, thanks, Dave.
w8ye 07-22-2012 05:25 PM
RE: what engine is this?
A Ralph Cunningham CD ignition rendition of the Zenoah G23
warbirdav8r 07-22-2012 05:38 PM
I've had g23's, This is alot bigger than a 23. Thanks though.
captinjohn 07-22-2012 05:47 PM
Look at the carb numbers on carb.....that may be a big clue. That is also a lot bigger carb that a 23cc engine would have...normally!
w8ye 07-22-2012 06:12 PM
Ralph converted a lot of none Zenoah engines.
I've a friend with a Ralph converted Sachs 3.2 using the original Makita concrete saw crank case
The engine in the picture has a Zenoah G62 coil. I think there were some versions of the G23 used that coil.
warbirdav8r 07-22-2012 06:33 PM
carb says 21-85 Walbro... Doing a c.i.d. formula of the internet, bore x bore x stroke x .7854 it comes to approx 5.0 cid. Hard to measure real good but I used conservative measurements. Dont have a clue as to brand though. Don't know how to get a muffler for it? Dont know what it is. Approx 40mm across the muffler bolt hole center to center..
captinjohn 07-22-2012 06:48 PM
Carb application guide= http://wem.walbro.com/distributors/S...retorGuide.PDF
captinjohn 07-22-2012 06:53 PM
ORIGINAL: warbirdav8r
Try the size like HD in front of that carb no...and use appplication chart.
Truckracer 07-22-2012 07:28 PM
ORIGINAL: w8ye
I think Ralph used that coil on some of his non-Zenoah conversions. Its pretty easy to say what that engine isn't but not so easy to say what it is! Cylinder looks a bit like a Sachs of some kind but I'm clueless from there.
w8ye 07-22-2012 07:40 PM
Does look chainsaw related.
The Sachs 5.8 is 40.25mm across the muffler screws
The DLE 55 is 40 mm across the muffler screws
captinjohn 07-23-2012 06:13 AM
What I want to know...does it run good...it should if RCIGN done the conversion. I am possitive he did. Hey....just PM him and ask.http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif try anique
AJsToyz 07-23-2012 06:37 AM
Send Ralph this picture and he will tell you what it is.
warbirdav8r 07-23-2012 03:30 PM
I found a ph. number on a sticker on the case, Try and see what happens. I dont know if It runs well or not as it doesn't have a muffler. Without knowing what it is I dont want to get a muffler I cant use..
w8ye 07-23-2012 04:35 PM
This is Ralph's contact info last year this time
<font size="2" face="comic sans ms" color="#333333"> 928 220 5721
[email protected] </font>
warbirdav8r 07-23-2012 04:41 PM
thanks for the info..
warbirdav8r 07-24-2012 12:47 PM
I found out that this is a Sachs engine 75cc, with the center pin of the battery jack being positive. Thats what I needed to know. Thanks for your help guys.
