RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   BCMA engine (https://www.rcuniverse.com/forum/gas-engines-142/11252585-bcma-engine.html)
Toysareforkids 10-06-2012 02:34 AM
BCMA engine
1 Attachment(s)
I have a BCMA 40 or 44, I don't know which. Can anyone tell me how to tell. Plus where I can find info, or a manual on the engine.
I search and I can only find old threads on it, which don't answer my questions, and the web site everyone use to use, seems to be down
Pat
BadAzzMaxx 10-06-2012 05:07 AM
RE: BCMA engine
The BCMA is a re-branded SPE and also the same as a MT40
If I remember right SPE is now MLD
Any two stroke gas engine out of China will have about the same manual,
Milton
KenLambert 10-06-2012 05:10 AM
RE: BCMA engine
It looks like a 42cc poulan
BadAzzMaxx 10-06-2012 05:36 AM
RE: BCMA engine
Sure does, I never looked at the pictures before posting, Just has a RCexl ignition with a BCMA label.
The BCMA were rear mounted.
Milton
ORIGINAL: KenLambert
Super08 10-06-2012 06:32 AM
RE: BCMA engine
I am thinking the only thing that is from BCMA is the ignition.
captinjohn 10-06-2012 06:55 AM
RE: BCMA engine
Hey if it runs good...run it like you stold it. I am sure it is a Poulan. Capt,nhttp://www.rcuniverse.com/forum/js/f.../thumbs_up.gif
Toysareforkids 10-06-2012 12:42 PM
RE: BCMA engine
Thankyouall!
After your suggestion of it being a Poulan 42, I searched it, and it is a Poulan 42.
I will now find a plan to a plane that I can build for it. I have no idea what yet!
Thanks, Pat</p>
KenLambert 10-06-2012 04:22 PM
RE: BCMA engine
it actualy looks like one of my mufflers
Lifer 10-07-2012 01:59 AM
RE: BCMA engine
I have been using one for about 5 years. It is currently installed in a Hangar 9 150-size P-47. Best prop for that setup has been a XOAR 19x8. Not as powerful as other engines in its class but it has been trouble free. I would be happy to answer any questions that you have if it would be of any help.
av8tor1977 10-07-2012 09:17 AM
RE: BCMA engine
I'm not sure it is a Poulan 42cc. The Poulan 42cc had the ignition coil mounted in the chain saw; not on the engine. Looks like this engine has mounts for a coil on the cylinder. It might be a Poulan 46cc.
AV8TOR
Ernie Misner 10-07-2012 09:10 PM
RE: BCMA engine
Is it a simple piston port or is there a reed block in there?
av8tor1977 10-07-2012 09:45 PM
RE: BCMA engine
1 Attachment(s)
It is piston ported. Here's a pic of a 42cc.
AV8TOR
KenLambert 10-08-2012 01:51 AM
RE: BCMA engine
thats the old style 42 they changed them for the EPA on the newer models. The 46cc has an oval carb adapter that slides on, but at this point it could be anything they all been sold and bought by so many companys.
Toysareforkids 10-08-2012 03:14 AM
RE: BCMA engine
1 Attachment(s)
Thanks guy's!
Here is some more pictures of it.
The exhaust has slots with nuts behind, to hold themuffler on.
What is the tubethat was added to the diaphragm cover for?
I got this engine in a trade, and I guess he didn't know what it is either.
Pat
captinjohn 10-08-2012 07:37 AM
RE: BCMA engine
The tube is so you can run a rubber line too the inside of the airplane to a place with dead air. Not always needed. For right now get it on a test stand or airplane to test run itand learn how to start &amp; run it. Also getting the carb set toothe right basic settings so it will run right. Capt,n
w8ye 10-08-2012 08:23 AM
RE: BCMA engine
It might be a Homelite 45?
Doesn't really matter as long as it runs.
Lifer 10-08-2012 08:35 AM
RE: BCMA engine
BCMA was run by a guy named Adam who lived in Colorado. He eventually gave up. The engines are made by SPE, and are 43cc. They are currently sold by Cermark and Chief RC.
Toysareforkids 10-08-2012 04:50 PM
RE: BCMA engine
ORIGINAL: av8tor1977
AV8TOR
It looks like you have yours on a stik. That is what I was thinking of building for mine. What inch wing do you have? What inch wing would you sudjest to use?
I'm going to scratch build mine so any size is ok. I'm thinking maybe a 70-80" wing. I have the plans for the 101" Bud Nosen big stik, that I could shrink down, or I also have the the plans for a 50" sweet &amp; low, that I could blow up. but I think I'd rather have a shoulder wing.
Pat
Toysareforkids 10-08-2012 04:52 PM
RE: BCMA engine
After looking at pictures of the SPE, they arenot the sameengines asmine.
Pat
ORIGINAL: Lifer
Toysareforkids 10-08-2012 05:06 PM
RE: BCMA engine
I kinda agree, But! If I hang it on the nose of a stik, and someone say's Hey! whats the engine your running, and I say a Poulan 42, and someone goes, No it's not! it's a Homelite 45, or something else,don't you know what you have!, I don't want to say no I don't know!
Other wise I could care less. Like you say, as long as it runsgood, it'll fly a plane.
I don't care what it is, I just want to know.
20 some years ago I had a Homelite on a GP100" Cap 21, but it looked different. I don't remember what size it was now.
Pat
ORIGINAL: w8ye
w8ye 10-08-2012 05:33 PM
RE: BCMA engine
The fact is . . . The engine was part of a trade and you're not sure what it is? And what is important is that it flies the plane and you are having fun.
The Poulan and Homelites like this were made different 10-15 yrs ago than they are now. These brands are still made today but they are a different design. In fact, now the Poulan, McCulloch, and Homelite in 46cc are identical except for the color.
Some important identifying features of the engine are that it has what's called a bolt on carb and was not one that had the carb mounted in the chainsaw case with a rubber bellows connecting the carb to the engine like they are today. The other important feature is that the coil originally fastened to the cylinder on this engine and was not mounted in the chainsaw case.
Some other facts about the engine was that these designs were typically from 33 to 50 cc. What rpm it turns what prop might be the best judge of what size it is?
There were probably more 42cc engines made than the other sizes?
w8ye 10-08-2012 06:00 PM
RE: BCMA engine
Here is a picture of a Poulan 46 and take notice that it has an adapter on the intake because this engine originally had a rubber boot to the carb. The carb was not a bolt on one.
http://images.rcuniverse.com/forum/U...95397_1454.jpg
http://images.rcuniverse.com/forum/U...31/Pj18958.jpg
http://images.rcuniverse.com/forum/U...31/Uo35146.jpg
http://images.rcuniverse.com/forum/u...30/Ig13411.jpg
w8ye 10-08-2012 06:06 PM
RE: BCMA engine
Here are a couple pictures of a Poulan 42. Notice the bolt on carb and magneto
http://images.rcuniverse.com/forum/U...88/Mk26837.jpg
http://images.rcuniverse.com/forum/U...88/Zv66943.jpg
w8ye 10-08-2012 06:26 PM
RE: BCMA engine
Later model Homelite 45 with the rubber boot type intake. There was a slightly earlier one with a bolt on intake
http://images.rcuniverse.com/forum/U...07/Ge95495.jpg
http://images.rcuniverse.com/forum/U...07/Rp44651.jpg
w8ye 10-08-2012 07:00 PM
RE: BCMA engine
Studying all the pictures, I think your engine is a Poulan 42.
They should pull a 18 X 10 around 7200?
It is difficult to identify these as they changed little things from year to year?
