RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Plug cable removal, replacement? (https://www.rcuniverse.com/forum/gas-engines-142/11514941-plug-cable-removal-replacement.html)
vertical grimmace 05-17-2013 11:05 PM
I have a Qudra 35 engine that I need to lengthen the plug cap cable on. How difficult is this to do, or is it possible? I need a little more length to get around my exhaust configuration. About 2". Any ideas of tips on the procedure would be great help. This is a magneto engine.
speedracerntrixie 05-18-2013 06:24 AM
RE: Plug cable removal, replacement?
Replace thecoil with one that has a longer wire. I may even have one in my shop. Give me mounting hole dimensions and wire length and I will take a look.
vertical grimmace 05-18-2013 07:01 AM
I will check dimensions today. That would certainly be easier. Thanks
vertical grimmace 05-18-2013 10:54 AM
I came to the conclusion that it would be better to make more room and will not have to lengthen the plug cap wire. I had to cut into an area of my plane I did not want to, but I think it will be best to leave the plug wire alone and stick with the current mag.
Thanks for the reply
