DLE-20 Gas / Oil Mixture
Looking for folks who have DLE's who can share with me their Gas / Oil Mixture ratios and types of Fuel and 2 Cycle oil they use.
I have a used DLE-20 that is supposedly broke in. Owners manual says: For optimum performance please use fresh or recently purchased 93 octane gasoline (87 octane gasoline will suffice) with a 30:1 gas/oil mixture. GAS/OIL Mixing Chart 1 Gallon Gasoline (128 floz/3.78L) / 2-Cycle Oil (4.26floz/125.68ml) = 30:1 ratio I plan on using premium gasoline as most everything around here has Ethanol in it. For the oil I was thinking of using Amsoil 2 Cycle. |
RE: DLE-20 Gas / Oil Mixture
As the instructions say, use 30:1.
Cheers |
used penziol at 32/1 from break N to regular use 17 x 6 APC prop
I use 32:1 and stay away from Amsoil unless you want to be buying another 20cc engine
The 20cc engines will sling the crank pin on anything less |
I use 30:1 redline oil on my dle engines and 40:1 on my DA engines. Redline works excellent<div>
</div> |
ORIGINAL: cubarican323 I use 30:1 redline oil on my dle engines and 40:1 on my DA engines. Redline works excellent<div> </div> |
I have two DLE20s I broke them in with 30:1 redline and never had a problem
[b]kswanson
Why are you thinking of using Amsoil? |
The DLE 20 must always and forever be 30:1 or it will loose the crank pn.
KLOTZ !! No more needs to be said !! ;)
