ralph cunningham conversions 80's
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2012863did ralph cunningham do electronic conversions as far back as the 80's, on quadras ? is this one?
I was thinking it was the later part of the 80's when he first started.
Some C&H conversions back then are hard to distinguish from Ralph Cunningham conversions. |
Originally Posted by w8ye
(Post 11838299)
Some C&H conversions back then are hard to distinguish from Ralph Cunningham conversions. BCCHI |
Originally Posted by WhiteRook
(Post 11838263)
BC |
its a CH, In fact , i sent it to them for a check up, works fine now.
(Post 11840137)
BCCHI |
Funny this posting is here... I have a Ralph Cunningham Poulan 60cc conversion that has run well for many years now. BUT, today after I mounted it on my TF Corsair, it wouldnt start, wouldnt even cough or sputter. So I did all the usual checks..fuel...air...spark errr no spark. Then I noticed the spark plug wire was hanging down from the ignition module. Not the spark plug boot but from inside the back casing of the modified mount.
I took it off the plane and removed the back plate. Lots of wires and stuff in there. The plug wire came out from the unit. Any thoughts how to fix this? Do I just shove the wire back in and hope it stays. (Not going to try that with a heavy warbird) Thanks! |
Contact Ralph and he'll surely get you set up. Have patience as he is trying unsuccessfully to retire, and also is sometimes gone to the various races.
How's the flying up there now Bill? Too hot down here in Tucson to fly unless you get up before the birds, and I don't like that.... AV8TOR |
it almost looks like someone handmade the piece that atttaches the magnet to the engine. its
basically a pioneer saw engine design. i have a 80's quad 100 that was converted and it has a bracket that attaches the magnet, it looks alot more professional, it also uses the C H ignition. |
Originally Posted by av8tor1977
(Post 11840470)
How's the flying up there now Bill? Too hot down here in Tucson to fly unless you get up before the birds, and I don't like that.... AV8TOR I do not get out early either. BCCHI AMA 2500 |
| All times are GMT -8. The time now is 09:23 PM. |
