RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   carb troubles (https://www.rcuniverse.com/forum/gas-engines-142/11627674-carb-troubles.html)
dirtybird 03-17-2016 11:22 AM
carb troubles
I tried ti start my RCGF 15 this morning. With the choke on I could see the gas being pumped into the carb. I could then start it but then it would quit. I have the needles almost all of the way out and there was no change. Where do you think it is plugged?
Meschmidt 03-17-2016 01:42 PM
I'd start with the carb screen inside if not using external filter. put the needles back to 1.25 turns out.
dirtybird 03-21-2016 07:10 AM
i bought a new carburetor and still have the same trouble. I have made sure the pulse hole is clear and all of the gaskets are secure. Is this a normal problem with the RCGF 15?
The new carb is one made for the Poulan chain saw. I got it for $10.
