RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   G38 - Muffler Modifications (https://www.rcuniverse.com/forum/gas-engines-142/2169375-g38-muffler-modifications.html)
apalsson 09-12-2004 11:39 PM
I am bolting a G38 into my Pepsi Chipmunk and need to modify the stock muffler to have a dual stack reaching down through the cowl. I need to solder (weld?, braze?) a couple of pipes to the miffler but don't know what metal the muffler is made of.
Does anyone know what kind of soldering will do this?
I tried silver solder but it wouldn't take.
Any help would be appreciated.
Regards
Ari
Robby 09-13-2004 12:38 AM
RE: G38 - Muffler Modifications
Ari,
Would help if you posted a pic so people could see what you have...
If it is a stock Z muffy, would be thin gauge steel...
Robby
thevirginian 09-13-2004 09:06 AM
First, the stock muffler ist stamped sheet metal. Secondly, you only get a lasting result if you use a TIG-welder and weld two thin walled stell tubes into two holes you need to drill first. You also need to close the louvre slots. Don't bother trying to solder. Even bracing does not work.
buyrbware 09-13-2004 02:49 PM
got a great solution......call b&B specialties, order a slim line pitts for that G-38. $44.00 bolts right on.
Tmoth4 09-13-2004 03:25 PM
ORIGINAL: apalsson
Regards
Ari
Braizing works great.
I'm using the same engine in my Chipmunk and did the same thing to the stock muffler (which is stamped steel.) It wasn't difficult at all.
Cut the hole in the muffler so it is a little tight over the tube you're using and then braize it. You'll also need to patch over the stock holes with a piece of thin sheet metal--also braized on.
I used only one tube, 5/8" ID steel, for the outlet. It doesn't seem to be very restrictive at all, and I have a smoke tap in the muffler for the TME smoke system. It works nice.
Jim
thevirginian 09-13-2004 06:12 PM
tmoth4;
I've been talking "long term" results here. I know, bracing will work. Question is for how long?
tom czenthe 09-13-2004 07:29 PM
1 Attachment(s)
Braizing is ok....
