RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DA50 Choke modify? (https://www.rcuniverse.com/forum/gas-engines-142/2832791-da50-choke-modify.html)
Ken Bryant 04-01-2005 08:38 PM
DA50 Choke modify?
I want to remove the lock on the choke on my DA50 and really have no idea how. Any hints on how to do this?
I will be actuating it with a seperate servo.
coony2787 04-01-2005 09:03 PM
RE: DA50 Choke modify?
Take the screw out that holds the choke plate on. Then remove the choke plate. You can now pull the rod out that actuate the plate. There is a ball and sping that mkaes the choke lock into place. Romove the ball and spring and then reassemble without the ball and spring. I hope that helps
Chad
Nogyro 04-01-2005 09:11 PM
1 Attachment(s)
No need to remove the lock when using a servo to operate it. I've got mine hooked to a Tower TS69 BB servo(42 oz) using the small wheel that comes with them. No problem. Can't remember if I used a 2-56 or 4-40 rod with ball links on both ends.
Ken Bryant 04-01-2005 11:24 PM
Chad,
Thanks for the info.
NoGyro,
Yea I thought of that, however I just wanted to take out that added resistance. I am going with longer pushrods than you and they can flex a touch. Just makes it a bit smoother.
Kfoss1 04-02-2005 08:25 AM
Ken, watch for side to side play when the spring and ball are removed. You might consider clipping a loop or two of the spring to keep it snug. And dont forget a little dab of locktite on the plate screw.;)
