Bme 50
? can you see the difference between the BME 50 and the 44
Bme 50
DEFINITELY
and if you wait for the new BME 55 EXTREME, you will have even more power than the 50 and CONSIDERABLY less weight than the 44 Jeff |
Bme 50
I have not heard anything about the BME 55. Damn I was talking with keith last night I should of asked. I called to confirm switching oil after two gallons. Keith said yes switch to Amsoil at 50:1 after two gallons. He is going to change the manual. I know someone posted that on this board. Do you have any specs on the BME 55? Keith is leaving for TOC today. Maybe it will be displayed there.
Chris |
Bme 50
I hear it is going to weigh less than 2 lbs!!
Bme 50
Keith will have the bme110 extreme for display at TOC which will be available for sale before the end of this year(or so I heard). The 55 extreme will come next year. I hope earlier rather than later ;)
Bme 50
I spoke to Keith about the BME55 EXTREME just the other day.
Same cylinder as the 110 same exhaust as the current 50 weight with ignition and plug is a tad over 2 lbs. It will have a radial mount that COMES WITH IT and bolts directly to your firewall. Carbueration is through a set of reed valves that is mounted in front of the cylinder directly over the crank. He is talkin about spinning 24" props with this engine. It will have the same size prop hub as the current 55. You better call and get your name on the list now because........ THEY ARE GOING FOR $499 just like the current 50 |
Bme 50
Wow!
I thought my AW 29% Edge was going to get a face lift this winter with a 50 (I have a 44 in it now) maybe I'll wait for the 55. 2 pounds is UNREAL! |
Bme 50
The 55 sounds nice. When did he say it will be available?
wgeffon, How does the AW 29% fly? I have been looking at the plane real hard. I also have a BME 44. My problem is I really don't like to build, and I don't have a lot of time for it. Have you heard anything about the 31% ARF coming out? I am also a professional pilot. I fly for Netjets. Chris |
BME
Must be made from titanium....
Bme 50
Nah, titanium is too heavy.
Must be made from ferro unobtanium. Seriously...no way on 2 pounds. That's what a Supertigre 2300 glow engine weighs without exhaust. And the BME will have over twice the displacement. The ST doesn't have a steel con rod. I don't find any excess metal on the ST, so this BME weight sounds like a pipe dream. |
Bme 50
"ferro unobtanium" I like that diablo ;)
Bme 50
2 pounds is seriously UNREAL! I am sure its gonna be a smooth running motor!
Bme 50
Are they planning on making a new airplane that balances with a 2 lbs gasser in the front? Or are we supposed to add 2 lbs of lead weight to the front? Can't put the batt packs up there on a gasser. Maybe we can run a 2 lb 12v gel cell for ignition!
Or maybe you can have a DP ultimate biplane with 42 lbs of thrust, 16" non scale landing gear to clear the prop and 1/4 scale servos in the wing to keep the flutter down! How do you like my HP edge with the new BME 55.....yes that is a $300 custom made 18x22 prop......wont hover but blows by my buddies turbine. |
Bme 50
I think the BME 55 sounds cool too, but...........
How in the world are we suppose to balance a plane designed for an engine that big when it weighs less than most engines half its size? Should we add dead weight or use bigger batteries? Maybe we should pop for some expensive light weight Li Polymer cells and just add dead weight. Seems like we're getting into situation where we're chasing our tails. (Pun intended) Wiz |
Bme 50
I am sure the 2 LBS is without battery, ignition, switch, and muffler. That will put it close to 3 LBS. I do agree that you better make sure how much weight you need up front before buying it.
Chris |
Bme 50
GUYS don't get your undies bunched!!.......Be creative, move radio equipment forward (like the elev servos and run pull pull) or maybe cut some lightening holes in the rear of the frame. MOST of the R-planes that are out there are designed heavy anyway. I know that it makes you feel better if the plane is structurally heavy and stiff!!????
Let me put it to you this way....... the H9 1/4 scale cap 232 wasn't meant to have a gasser on it, but lots of people went that route anyway. I did. Most of them ended up WAY too heavy. I took out that which wasn't needed on this plane and ended up at 13.5 pounds. That is about what this plane weighed with the YS 1.40 on it. Now IMAGINE the same plane with the new BME 55 on it weighing in at 12.5 pounds............................HOLY ***** !!!!! Now you are truelly getting the thrust to weight ratio up there like the BIG BOYS. GUESSING but 32 lbs thrust to 12.5 lbs of plane....... THIS ENGINE IS GOING TO BE GREAT, just quit using your tunnel vision. Jeff |
Bme 50
We are presently flying a 11Lb 1280 sq in model with a 40RE and pipe - this power/ weight combo is very fun!
When you get into this 20 oz ft realm -and swinging BIG props - it is competely different I am using trimmed 22x12 props and 20 10 stuff - We also took it to the TOC and some of the guys flew it on Monday -- Tunnel vision is sticking with HEAVY arfs---get out the sticks and glue -then your new engine will really be a blast. |
Bme 50
A BME 55 that only weighs 2 lbs? This one I will have to see before I believe. There is hardly any wasted metal on the current engines, so how are the savings achieved? Ceramics? You cannot pull any significant weight off of the crankshaft or the rod if you want decent life and robustness, and the crankcases are already aluminum. There is some wishful thinking going on here I suspect.
And with an engine that weighs half as much but still has the same rpms and power output, the pressure pulses will be the same and vibration will a problem. Engine non-reciprocating weight helps dampen and absorb vibration. As the reciprocating mass becomes proportionally larger than the still and rotating masses, you are gonna have the shakes. Since my planes already balance right on with the "heavier" conventional gasoline engines, what am I gonna do? Trying to pull the equivalent weight difference out of the rear is not a simple matter. I don't want flimsy airplanes. I don't think that today's engines are much if any overweight as they are. |
Bme 50
MR Hanson,
I agree tunnel vision is sticking to ARFs. That is why I have only done the one. I build eveything I fly other than the H9 CAP. Tommy, I understand that which you are saying, but look at what BME did with the 110, it weighs just a little more than 3.5 pounds. The only reason the 55 isn't UNDER 2 pounds is because even though it is only half the size of the 110, It still has the majority of the 110 crankcase. So physically, it is more than half of a 110. If done correctly, any engine can run smoothly regardless of it's weight. You last comment states that you are happy with the "HEAVY WEIGHTS". Just imagine shaving another 2 pounds off of a 1/3 scale plane. Imagine the light wing loading. You could use canisters without becoming over weight. You could add 10 more oz of fuel AND smoke oil. You could mount a digi CAM corder permanantly................ Jeff |
Bme 50
Everyone is interested in "newer/lighter " engines - There may be a bit of "wistfulness" afoot ----
From what I have seen in single cyl designs -- 2.5 lbs would seem to be a pretty light target - small plug - thin wall cyl, slipper piston etc.. The extra bits tho - still weigh the same - a decent, quiet exhaust setup - close to 10 ounces -a blatty stack, - a lot less.- an ignition -2 ozs min - we had some of these done once - using a coil mounted to the engine - fed by a small electronics package - the batt- another 2-4 ozs The prop? well these vary by a 3-1weight factor! -spinner etc.. Bottom line - the % difference in the entire"powerunit" will be quite small. Getting a very light , very smooth power package is still quite a trick. The big rub is that the torque reaction really is tough to control. Overbalanced cranks and trick ignitions really help here but a poorly adjusted carb and a light , flexible prop , can ruin the best efforts for smooth operation--regardless of the mfgr. |
Bme 50
I agree with most of what you said Dick, but in the case of my H9 CAP, don't you think shaving nearly a full pound off of an 1100 sq" ship would make a SUBSTANTIAL difference. Taking it from 13.5 lbs. to 12.5 lbs. This is the weight of the plane with a GLOW engine.
Secondly, I really doubt that Keith is going to put JUNK on the market. By that I mean the way you described the engine. This IS the 110 basically cut in half. So what you said would have to mean that his 110 is going to be junk also. I just do not think so. You see alot of these same types of comments were made when Keith made the 102. IT IS TOO LIGHT. CYL IS TOO THIN....BLA BLA BLA BLA..... Turned out to be a very successful engine didn't it!!!! EXPECT NOTHING BUT THE BEST FROM THE 110 and 55 EXTREME Jeff |
Bme 50
What are you saying?
I don't recall saying anything negative -I commented that saving weight is a tough job--for anybody. |
Bme 50
What I am saying is this engine doe not make sense for the currenty crop of airplanes that we have out there
So what you are saying is: The New most powerfull engine is designed for 1.20 planes? Put it in a 73" wing that has the ground clearance for an 18" prop and find a 18x20 prop? what good would that prop be for hovering? or build an 80" plane light in the tail? How about an 80" cap with a flat stab? or elveator sevos in the front of the fuse??????? with rods to control the surfaces??? There are plenty of engines out there that give us overkill performance as it is. This is not making sense.....and some of us do not have the time to build. You are bashing ARF's, but take a look at the GP EXTRA 300s and let me know how long it would take you to finish that plane in that exact color sceme including the painting of the cowl in checkers with gold trim...........................your budget is $399 and the quality of the finishing must be the same, and throw in a 3 1/2 aluminum spinner and 4-40 hardware!!!!! I have the time to fix little things on ARF's, i do not have the time to build and finish a plane that would cost me twice as much. And for what? Rediculous speed and power that can't be used? We are reaching the speed envelope already in 78" 80" planes? 42lbs of thrust on a 13 lbs plane..........have fun on the downline braking, landing, and with aileron flutter. FYI .....a search on the web brings up nothing about a BME 55 extreme. |
Bme 50
Dick,
My first comment was in reference to your comment "Bottom line - the % difference in the entire"powerunit" will be quite small." The rest of what I said must have been a brain fart. I don't know where it came from. lgodin, If this engine turns out to be what Keith says, it could EASILY replace most of the 60cc engines and have less weight. Less weight is ALWAYS good, you just have to look at different ways to get the plane balanced. It is not impossible. Move elev servos as far forward as possible, same with the rudder servo(s). I have had GREAT success with radio equipment within 6 inches of engine ignition, so I would NOT be the least bit afraid to shove everything that close to the ignition module. Get the ignition module up on the firewall and there you have it. If any lead has to be added, it would be kept to a minimum. I personally think this engine would be EXCELLENT on ANY 90" and below aerobatic aircraft. The new AEROWORKS 31% ARF would fly very well with this engine. If this engine turns a 24" prop like Keith told me, it should have the thrust of most of the current 70cc engines. Jeff |
Bme 50
If you look at the weight of a gas engine - say 40-50 cc- you must include all accessories which make it a viable quiet setup-
So if the basic engine weighs 2.5 lb -or 3 lbs - -that weight is only part of the "power unit". The total is more like 3.5-4 lbs . On a percentage scale - a bare engine weight savings of 8 ounces (optomistic savings) figures out on a 3.5 lb package as 8/56-or a 14% savings on weight of the "power unit". A 32 oz 40-50 cc gasoline engine may be a possibility - In any case - lets see what actually transpires first--- As an example - When I tried making 11 lb 1280 sq in model - with a 40 and a pipe - I was wondering how to do it- and ended up under that weight! One never knows how light stuff can be until it is really given an effort. |
Bme 50
AMEN
Jeff |
The" Super-engine"
A 55cc engine that weighs 2 lb. & has the power of a 60 or 70?Yeah,right.This is getting better.What's Keith been smoking latley?
Bme 50
Laugh all you want but i talked with kieth today and it will swing a menz standard 22/10 at 7200 rpms
Bme 50
No one is doubting the power of a 55cc gasser.
We're doubting the weight claims of 2 lbs. Stare really hard at either an OS 1.40 RX or a Supertigre 2300 and then tell me how you add a pumper carb and an ignition and a set of reed valves and a spark plug and a steel con rod instead of an aluminum one and DOUBLE the displacement without gaining weight. This sounds like Enron and Arthur Anderson are weighing the motor. Will it weigh 2.0, 2.1, 2.2, 2.3, 2.4, 2.5, 2.6, 2.7, 2.8, 2.9, pounds? Perhaps they rounded 2.8 lbs down to 2 lbs??? |
Bme 50
The power output sounds reasonable - my new 50 ran in very high 6000 range - still new -on MenzS22x10-
I would expect that kind of rpm at sealevel -on 55cc. |
Bme 50
I dont know where these "plenty of overkill" engines are???
Especially if you dont like Glow!!! |
New engines
I just visited the Desert Aircraft website, and noticed they are offering a new single cylinder engine that looks pretty impressive to me...the DA-50-R ....see what you guys think....
http://www.desertaircraft.com/da50.html |
55 Ext.
I spoke with Keith Friday. He said they were shooting for 2.5 pounds, sounding like they were not there yet. Hoping for a finished product after the first of the year or early spring.
Sounds Good!!!!!!. |
Bme 50
ITS NEW YEAR NOW.....
Happy New Year to all Now ....... any news from keith ?? azuz |
Bme 50
It sounds as though you haven't heard about the new foamed ceramic pistons. ;)
Bme 50
Foamed ceramic pistons?
In production anywhere in the World? Can you get on the phone and order one? You could also make the thing out of beryllium, but then there might not be anyone around in a year to do the warranty work. I will reserve my conclusions until the BME 110 is actually in production and people are flying the thing. Then we can all speculate some more on the future arrival of the 55 and how close it will come to meeting the design target. The DA-50 is also just hitting the streets now. Let's get some feedback here from the pilots before everyone pronounces it a winner or a loser based on the reputation of DA alone. |
Bme 50
imagine this. . BME55 . .quiet pipe in the belly, 20-10 three blade. . 80 dB .. in a pattern plane. . gives a whole new meaning to the term "unlimited performance".
Bme 50
Having been into the gas powered pattern model design trial since--August - I have found a few thing s worth thinking about -
This is based on hands on flying and as of today - a LOT of it -using a 40 REZDZ and a tuned setup- First off- the low sound level is possible - but you need more pitch - I really don't expect to see the best results on 10" pitch- the reason why is that at lower revs -you need more pitch. A super duper low engine weight is nice -but not all that important-- any competent builder can hit 11 lbs with any decent 40 --no secret tricks needed . The models do fly different as compared with the existing 9-10-11 lb 1.4 powered models - the power - raw thrust available can be easily overused -and flying gets jerky -not the fluid flight as seen for top drawer FAI. The new series of 50 engines on the market should easily be capable of working for the present FAI schedules. Here is the BUT! I really think, that FAI has a chance of makeing a change to a slightly bigger /heavier model-so I am not doing anything more with my current project except for using it to work out the new IMAC Unlimited pattern - It is great for that - I hate doing up a design -then having the rules change - FAI votes in March -on new rules for the next cycle - some countries are already proposing increased weight limits for their own use . And why not - as far as I can see - the use of a modern 40-50 cc gasser has it all over any overpriced /expensive fuel glow engine now being used - I have used both and I would not go back to the others -which were really not a problem for me - just that I think their time came -and has gone -RIP |
Bme 50
Knowing the FAI. . they might do something really silly if they go to larger planes. . . . like make an engine limit of 50cc's . . . . . that would be EVIL!!!
Bme 50
Evil?...yeah,right...evil for YS & OS.
| All times are GMT -8. The time now is 08:37 AM. |
