RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   What are you using for a test stand? (https://www.rcuniverse.com/forum/gas-engines-142/3660214-what-you-using-test-stand.html)
davewallace 12-16-2005 10:56 AM
Hello everyone,
I have seen a few teststand setups and procedures that scare me a little due to safety concerns. It would be great if you could post pictures of your setup and make safety suggestions. Remenbering that SAFETY IS PARAMOUNT.
Thanks, Dave
Richard L. 12-16-2005 12:39 PM
RE: What are you using for a test stand?
PSP sells a pretty nice looking test stand. I don't know if it can handle a gas engine though.
Hobbsy 12-16-2005 01:06 PM
See here. http://www.pspmfg.com/BackMountAdapter.html
exeter_acres 12-16-2005 01:21 PM
my airframes;)
Robby 12-16-2005 01:43 PM
I'm the same as exeter_acres on this one....
Look at it this way,, What do you use for a 'test stand'
on your weed wacker or leaf blower...? And they last
HOW long...?
And BTW,, Homer,, its not 5 o'clock somewhere,,
its only 3 o'clock somewhere,, so again,, yer LATE!!! :)
Volfy 12-16-2005 01:52 PM
1 Attachment(s)
My test stand is a sawhorse made of 2x4s. Cheap, effective, and I've had everything from a .32 Wankel glow engine to 100cc gas twins on it. Accomodating odd setups like big long tuned pipes is no problem. All it takes is some 2x4 and 2x6 scrap pieces and a screwgun.
To me, safety means the test stand must:
1. Be extremely sturdy
2. Be able to mount engine securely, preferably using the exact same mounting method as on aircraft
2. Place the engine at proper working height (slightly above waist level)
3. Be able to mount the engine in various orientations (to make access to adjustment points easy.
4. Be able to be reposition and relocated as required (for example, so the exhaust blows downwind)
Antique 12-16-2005 02:04 PM
A Black and Decker Workmate is a very good test stand..I took the stock top off and replaced it with a couple 2x10s..I run 3W 150s on it with no problem...Put the vertical piece on the same side as the step...It folds down for storage or transportation..I'm on the second one in 18 years, they eventually get loose from vibration...
exeter_acres 12-16-2005 02:36 PM
ORIGINAL: Robby
Well heck, I best go pour me one then!:D
I have had it happen several times where an engine is peachy on a test stand, but won't run right on the airframe....
so no more test stands for me....
rmh 12-16-2005 04:42 PM
1 Attachment(s)
awwww-
exeter_acres 12-16-2005 05:13 PM
ORIGINAL: dick Hanson
awwww-
I actually like that stand...but if you put a couple more wheels on it....you could tool around the neighborhood
krayzc-RCU 12-16-2005 06:25 PM
test stand what is that?
i guess i have been using firewalls?[:o]
doubledee 12-16-2005 08:01 PM
Wow, lookee there, the original prototype the the Cessna 337.:)
doubledee
pocatosaras 12-16-2005 10:02 PM
1 Attachment(s)
ORIGINAL: krayzc-RCU
LOL, A truly honest man!!:D:D:D
Me too! Although I've been known to use the vise mounted on my worktable.....
rmh 12-16-2005 10:14 PM
It has retracts -
Flip and Fly 12-16-2005 10:21 PM
Dick, it looks like you just pulled in from another nice drive in the country.
edgeman55 12-17-2005 06:10 PM
Looks nice Dick,can you hover it.
