RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Taurus 4.2 Throttle position (https://www.rcuniverse.com/forum/gas-engines-142/372075-taurus-4-2-throttle-position.html)
HarleyRider 11-19-2002 03:03 AM
I received my new Taurus 4.2 today and it is a fine looking engine. I am looking for ideas on how to connect the throttle cable. Throttle connection is almost 90 degrees to the cylinder head. I don't see any way to mount a bellcrank so I can move the throttle butterfly in the right direction. There is no way to mount some type of standoff for the bellcrank. On the G62 you can drill a hole in the mount for a standoff. Works quite well. I have standoffs on my 2 G23's, G62, and Taurus 2.6.
Thanks for any ideas you can give me.
Antique 11-19-2002 04:43 AM
AJF 2 11-20-2002 06:40 PM
On mine I ran a beam off of the firewall down the side of the engine(1/2 spruce, I think)--I then mounted the 90 degree bellcrank on the beam--then ran a rod to the carb.
AJF--2 11-20-2002 10:49 PM
1 Attachment(s)
Maybe a picture will help.
HarleyRider 11-21-2002 02:06 AM
AJF--2
Thanks that is an excellent idea, I will try it and thanks for taking the time.
