EVO300 engine.
Just ordred one of those beasts.
EVO engines from www.evo-engines.com or www.forgues-research.com Gonna be use in a 1/2 scale Christen Eagel. Preliminary equipment(still in planning stage) servoes Hitec 5995Tg(12pcs), plane kit from www.emhw.de, mufflers 2x 105 Krumscheids, 2xhitec HPD-07RH receivers, optical kabels from receiver to servoes, servoes running on 2xlipo, receivers running on 1xlipo, ignition 2xlipo, prop size between 36-40 " 2-blade, fuel cap 60 oz, no smoke system. Does this sound great or what? Joen |
RE: EVO300 engine.
Choice! Keep us informed. Why no smoke?
RE: EVO300 engine.
Weight issue, we're not allowed to fly planes over 55lbs at take off, including fuel and smoke, next I work in the enviromental sector for cleaning up oil after a spill :D, with this setup I should be able to keep it at 54-54,5 lbs, by the way the engine will be an version made of magnesium weighing in at 14 lbs
Joen |
RE: EVO300 engine.
joenella,
That sounds impressive, let us know how that motor works. I am interested in the new EVO motors. |
RE: EVO300 engine.
ORIGINAL: joenella Just ordred one of those beasts. EVO engines from www.evo-engines.com or www.forgues-research.com Gonna be use in a 1/2 scale Christen Eagel. Preliminary equipment(still in planning stage) servoes Hitec 5995Tg(12pcs), plane kit from www.emhw.de, mufflers 2x 105 Krumscheids, 2xhitec HPD-07RH receivers, optical kabels from receiver to servoes, servoes running on 2xlipo, receivers running on 1xlipo, ignition 2xlipo, prop size between 36-40 " 2-blade, fuel cap 60 oz, no smoke system. Does this sound great or what? Joen I can't seem to be able to open the airplane kit's web site, also to whom are wondering, about the optics they are Fiber Optic extensions that I produce. What a project, modern fighter jets don't have that much thrust to weight ratio. Awesome Roger |
RE: EVO300 engine.
RE: EVO300 engine.
| All times are GMT -8. The time now is 12:39 PM. |
