RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Engine mounting options (https://www.rcuniverse.com/forum/gas-engines-142/387060-engine-mounting-options.html)
Wheelsup-RCU 11-28-2002 05:02 AM
I have a Carden Extra 300 which I bought used/repaired that has a bit of glass on it, so it is a bit overweight. My G-62 gets it around the pea patch, but clearly it needs more power. I prefer an engine that mounts like the G-62, flat to the firewall. I looked at 3W 75 etc., but they require a hole in the firewall for carb. I was thinking about Fuji, but the 86 is too long for the cowl: 7+" where I need only 5.25, so I will likely get a single cylinder engine, but which one? How does the ZDZ 80 mount? Or is there another option I should explore?
Torque'n 11-28-2002 05:18 AM
Phil, call up Bobby at Cactus Aviation right there in Tuscon AZ. 3w does make a 3w 75. They have the rear carb like you mention, but they also make a side carb so you will not have to drill any holes in the firewall. Hope this helps.
Garrett Morrison
ps. Cactus Aviations phone # is 520-721-0087
Wheelsup-RCU 11-28-2002 05:25 AM
Thanks for the swift and helpful suggestion.
Jemo 11-28-2002 12:26 PM
http://www.aircraftinternational.com/
Here is a picture of one.
I have one and it is awesome, on my Carden Extra 300.
