RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   electronic pickup position (https://www.rcuniverse.com/forum/gas-engines-142/3925936-electronic-pickup-position.html)
bronco_ov10a 02-18-2006 12:13 AM
Hi all
I have a BT-64eis and this the first gas engine that I have owned although i have been modelling for 40 odd years.
In all the pictures that i have seen the sensor unit is mounted on the top position of the crankcase where as mine is mounted below the crankshaft. I note that the parts breakdown pic on page 11 shows it below the shaft.
Can I change it to the top if I rotate the rotor 180 degrees, or will the woodruff key dictate the fitting of the rotor.
Thanks guys
Cheers Geoff
Bax 02-20-2006 02:31 PM
RE: electronic pickup position
The EI unit, as installed, is mounted correctly. Don't change it. The pictures may be of an earlier version.
bronco_ov10a 02-20-2006 10:09 PM
Thanks for that info Bill on the sensor position. We do not have a distrubitor for these engines in Australia so I rely on the experience of other users
Cheers Geoff
