Evolution 26GT Question
I am on my first tank at 32:1 for breakin. At factory carb settings. Engine runs great. The front bearing has 1/16 axial play and this is the outer bearing race moving back and fourth in the crankcase casting. Also have quite a bit of black oil coming out around the front bearing. Is this normal ?? Thanks, Dan |
RE: Evolution 26GT Question
no to both - call your vender -
and there is NO factory carb setting -unless you mean recommended settings IF they are about right - that is just luck you must learn to adjust em |
Thanks Dick,
Yes, I was referring to recommended initial settings on the carb. It's running a tad rich right now but I don't normally start leaning out until around the second tank or so. I figured something was not right with the bearing but wanted to be sure. None of my Fuji's or Zenoah's ever had this problem. This is the first Evolution I have tried ! |
Is it MVVS 26? loook very similar?
Today I noticed that when the engine is cold that the end play is gone. Only about .003.
Cranked it up again and when hot end play is 1/16. Cooled off, back to .003. Cylinder temp has never exceeded 226 degrees. Any further thoughts ??? wit-RCU Yes, it's a rebranded MVVS. |
| All times are GMT -8. The time now is 06:12 AM. |
