RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Need help on Engine ID (https://www.rcuniverse.com/forum/gas-engines-142/434486-need-help-engine-id.html)
Charlie E 12-23-2002 03:12 AM
1 Attachment(s)
I got this engine on a trade. I hope someone can tell me what this engine is. The owner had no use for it and really I don't either. I am into much smaller planes and engines. Thanks for your help.
The only thing on the cylinder is:
MAHLE
44ZN 18
CARBURATOR: WALBRO
bn120 12-23-2002 03:43 AM
looks like a sachs 44cc I will buy it if you dont need it,does it have the ignition and how much?
Darin
[email protected]
tkg 12-23-2002 06:02 AM
How about a Sachs 3.2. Looks like an A&M. You have the ignition, but the engine is missing the timing ring on the front.
Antique 12-23-2002 06:04 AM
It's an old A&M Sachs 3.2..The ignition sensor is missing from under the hub...Take the single bolt adapter off the hub and look at the crankshaft...If it's smooth on the end it's not a Sachs crank...Some worked well, some not so well...A Sachs crank is a direct replacement..(But $$$$) .....
Hello, TKG.. :D
A&M was the only manufacturer to paint the top of the cylinder....
Charlie E 12-23-2002 11:32 AM
1 Attachment(s)
The pic below shows the accessories that came with the engine.
I can email more Pics.
Sell Price for everything: $300.00
Buyer pays for shipping.
captinjohn 12-23-2002 03:24 PM
engine parts
Gootrod: If you do not sell complete, will you list the parts for sale? Thanks CJ
Bassman-RCU 01-07-2003 05:03 AM
1 Attachment(s)
I just bought the same engine. However, the top of the cylinder is not painted. The markings are the same. The ignition has "A&M Aircraft/Sachs".
This is the first time I have owned anything other than glow engines. I have no idea when this engine was last run. I do not know what ratio oil/gas to run. Any help will be appreciated. Can anyone tell me how to test the ignition or purchase a new ignition?
One last question, does anyone know where I can find any specs for this engine?
Antique 01-07-2003 03:00 PM
Plug the battery and sensor into the circuit..Lay the spark plug against the cylinder and turn the engine past Top dead center..the plug should spark..
Specs...Bore 1.73, stroke 1.34..Made from a Sachs model 111 or 115 chainsaw with a machined case by A&M...Look at the con rod..If it's copper color it's a Sachs, if it's not it was made by A&M...
Mix the oil at whatever the oil manufacturer says, usually 32 or 50-1 ....
Bassman-RCU 01-07-2003 06:00 PM
rcing,
