RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   da50 problem (https://www.rcuniverse.com/forum/gas-engines-142/4465068-da50-problem.html)
sunny7775 07-05-2006 09:24 AM
da50 problem
I just test flew my new Wild Hare Extra300 with a DA50 on it, and every time I throttled back on my landing approach the motor would die. I left the needle adjustment on the factory setttings for the test flight, ran fine just died when it was throttled down. Had idle set at around 1900 rpm, 22x8 prop .Any suggestions?
Mike
3DFix 07-05-2006 11:08 AM
RE: da50 problem
It sounds like you need to adjust your carb.
Peak the RPM's (leaner) with the high needle and back off about 200 rpm (richer). Lean the low needle until it dies when you open the throttle, then open (richen) the low an 1/8 turn at a time until the transition is good. Repeat the steps for the high again. When your low side is correct the engine should be able to idle for a long time without changing RPM'S.
If your engine is new the high end should be a little rich. Make sure the motor is making a slight gurgling sound at full throttle.
Good Luck
jongurley 07-05-2006 04:49 PM
RE: da50 problem
Exactly,,,but I would just say to do the increments in 1/16 of a turn, I know that sounds picky but these motors are tempermental when you get them close to optimal settings,,
sunny7775 07-05-2006 05:16 PM
RE: da50 problem
Thanks for the advice, it is greatly appreciated. Will adjust the needles.
Mike
srm99 07-05-2006 05:43 PM
RE: da50 problem
i would adjust your idial speed when u have warmed the engine as they are different when cold and warm and adjust those needles high first to peak then back off 100rpm then low to have smouth transition
Josey Wales 07-05-2006 06:07 PM
RE: da50 problem
ORIGINAL: sunny7775
Mike
Both my DA50's came adjusted way to rich..Ive played around with the needles so many times and I always seem to end up with the high at 1 3/4-2 turns out and the low 1 3/4 out....Once you get close, just turn 1/8 or less..like Joe said..it doesnt take much
sunny7775 07-05-2006 06:12 PM
RE: da50 problem
Don't want to sound stupid, but do you adjust while it's running or stop the motor,adjust and retry?
Mike
Josey Wales 07-05-2006 06:39 PM
RE: da50 problem
I shut it down, adjust the needles then start back up..When it gets close I just fly it then adjust after each flight until I get it perfect..tuning on the ground will get you close, but what the motor does in the air is more important and most of the time once you get in the air, the tune will change..thats why I start it on the rich side (not too rich though) then lean after each flight as necessary
sunny7775 07-05-2006 06:55 PM
RE: da50 problem
Thanks again for the info, hopefully will get a chance to tune it tomorrow. Will post how it goes.
Mike
srm99 07-05-2006 07:14 PM
RE: da50 problem
what u can do is put a peice of ridged tube but enough to push over needle so u can do while running its up to u as both will work .
vanguard 07-06-2006 10:02 PM
RE: da50 problem
Have any of you had problems starting your DA50? Recently mine has become a pain to start at times. It will pop once when choked then start and die on about the 5 flip unchoked. It will then start and die several times before it stays running. Sometimes hard to start after a flight and refueling. The high needle is at about 1 3/4 the low is at 1 1/2. Once its running, the engine performs really well.
srm99 07-06-2006 10:51 PM
RE: da50 problem
u can try and richin up your low end a tad
jon595 07-08-2006 04:58 PM
RE: da50 problem
Vanguard,
Mine acted as you described. Almost like it needed to run for a while before it would run without dying. What I thought was it being cold natured was actuallt some kind of trash that was in the carb and broke loose, causing it to die. The trash looked like it had been there since it was manufactured. Inlet screen was clean, and I use a filter in-line, and a Walbro filtered clunk in my fuel jug. My needle setting are close to yours, low end just a tad leaner, I fly at sea-level. Cleaned it w/ carb spray and a little compressed air and have not had any troubles since.
Good luck,
Jon
