RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Will this work.. (https://www.rcuniverse.com/forum/gas-engines-142/4737713-will-work.html)
azhar 09-11-2006 08:58 PM
Will this work..
1 Attachment(s)
I am holding up the cannister as shown in the pics below. I am assuming that tygon will be able to withstand the heat from the exhaust. Appreciate any feedback
tkg 09-11-2006 09:01 PM
RE: Will this work..
Tygon will melt!!!! Its plastic
Use silicon if not exposed to the exhaust or neoprene.
azhar 09-11-2006 09:13 PM
You are right...will silicon tubing work? Like those nitro fuel tubing?
Azhar
RTK 09-11-2006 09:58 PM
As tkg said, silicon or neoprene.
I have been using silicon tubing (fuel tubing) on my canister set-up without any problems. Though the tubing is on the canister itself and not exactly where your's is located in the second picture.
Rcpilot 09-11-2006 10:10 PM
Yes. Use glow fuel tubing. It's silicone.
azhar 09-11-2006 10:13 PM
Thanks folks, ,I forgot about tygon...will use silicon.
Azhar
DKjens 09-12-2006 02:38 PM
I'm pretty sure the silicone tubing will still melt in those locations, and the tie wraps will certainly melt and split. I have two MTW TD125 cans in a KatanaS with a Kroma180i in the nose. These cans get so danged hot, I had to but header wrap around them where my silicone tube pieces but up against them.
DKjens
