Bme 44 - Vibration ??
I HAVE A BME 44 THAT REALLY SHAKES -- I HAVE BALANCED PROP AND ALL OF THE USUAL THINGS -- SHOULD I SEND IT TO B AND B TO FIX ( I HAVE USE THEM BEFORE AND KNOW HOW TO FIND THEM ) OR SHOULD I SEND IT TO BME PEOPLE ( DON'T KNOW HOW TO FIND THEM ?? ) --- I BOUGHT THIS OFF OF RCU -- IT WAS USED BUT WAS TOLD IT WAS OK .. ENGINE STARTS FINE ,, IT REALLY SHAKES AT ALL SPEEDS ????? THANKS DENNIS
Make sure you are not running it on the rich side. All engines will shake a bit more if they are rich. Pull the plug out and see if it has a nice TAN color. If it is TAN then you are OK, but if it is black it is running rich. Lean conditions would be represented by a white color.
Good Luck, |
Check the run-out of the crank and prop hub.... Possibly it is bent...
Rich engines usually vibrate most at low rpm through transition... |
| All times are GMT -8. The time now is 11:33 AM. |
