Kill Switch for Taurus TS-52, What to use?
Hope someone could help me out here, I will be installing a Taurus TS-52 in my PW Extra300s and being my first gasser, I do not know how to install a kill switch. I would like to have both a manual operated as well as a servo operated switch. Is there anything being sold that could do this or do any of you guys know of a method that works. Any help is greatly appreciated!
Thanks, Justin :) |
http://www.electrodynam.com/cgi-loca...69b+1057170722
grind or dremil off the flang on the choke and install a steering arm like the ones used on trainers to run your choke servo with the carbon fiber nyrod. ElectroDynamics makes the fiber optic kill switch |
Thanks, just what I was looking for! :D
Justin |
Originally posted by Extra300s7 Thanks, just what I was looking for! :D Justin 1- choke the engine via TX 2-full choke will instantly kill the engine. Much better way in my opinion. Choke servo |
but if you choke the engine out it becomes difficult to start again....
Originally posted by davey_flyer but if you choke the engine out it becomes difficult to start again.... |
Are you using fiber optic servo leads?
Originally posted by Extra300s7 Are you using fiber optic servo leads? I'm not trying to sell anything. I don't use Fiber Optic in the smaller airplane but still use the choke servo. |
why would you need to use FO if it's in the Engine compartment?
Originally posted by davey_flyer why would you need to use FO if it's in the Engine compartment? the ignition battery powers the throttle and choke servo and everything electrical in the engine compartment stays there and the only thing that goes to the receiver is the Fiber Optic cable which is immune to any noise |
| All times are GMT -8. The time now is 09:20 PM. |
