RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DA 50 Engine HELP (https://www.rcuniverse.com/forum/gas-engines-142/5585132-da-50-engine-help.html)
Michael Basson 03-19-2007 02:43 PM
DA 50 Engine HELP
Hi all,
I have a new DA 50 engine. The odd thing is that it has 5 flights on it now but it feels like there is no compression. My other DA 50 feels fine. This one however when you take your index finger on the tip of the prop and turn it, it turns without any effort. when i had a deadstick the weekend the prop turns every now and then while on the deadstick approach. When i turn it clockwise however there is alot of resistance??
Any help and yes there is a sparkplug in and tightend.:D
Regards
Michael
frieshoo 03-19-2007 03:01 PM
RE: DA 50 Engine HELP
Could be the piston ring. I had a Evolution 45 do the same, and the ring was "bad"... according to Horizon... I sent it to them, and they fixed it.... It's got compression now.
Cobra1 03-20-2007 11:53 AM
Sounds like a ring problem to me also. Send it to DA and they will make it right.....:)
Tired Old Man 03-20-2007 03:00 PM
Send it back after making the phone call. Sounds like it got really hot and stuck a ring, or ran without oil. I'll go with hot first since the no oil version would be obvious when you looked in the exhaust port.
