RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DA 100 Help (https://www.rcuniverse.com/forum/gas-engines-142/5629352-da-100-help.html)
Warwick Laken 03-28-2007 10:04 AM
DA 100 Help
Can anyone come up with some help so I can fly tomorrow.
I have fitted a new DA 100 into a CAP 589.
The engine starts well and runs smoothly but only to 2500 rpm, it will not run faster. Throttle is opening all the way and the choke is not stuck closed.
The fuel supply is good and have tried all adjustments on the carb. I am using a Mezlick 27/10 prop.
Any sugestions please
Warwick Laken
david57 03-28-2007 10:22 AM
RE: DA 100 Help
Are you sure both cylinders are running?
Warwick Laken 03-28-2007 10:35 AM
RE: DA 100 Help
I am pretty sure they are, BUT
DMcQuinn 03-28-2007 10:54 AM
RE: DA 100 Help
Sometimes one half of the ignition fails. After the engine runs at 2500 rpm for about 30 or 60 seconds, feel the cylinder temperature. Is one cold and the other hot? If so, swap the ignition wires and repeat the test.
RTK 03-28-2007 12:45 PM
RE: DA 100 Help
If it is running on only one cylinder do not run it that way very long. The one working cylinder tends to get hot very fast.
Tired Old Man 03-28-2007 02:22 PM
RE: DA 100 Help
VERY, VERY HOT!!!!!!!! Enought to fry the piston, cylinder, and ring in very short order!!
k5mog 03-29-2007 09:04 PM
RE: DA 100 Help
Warick
A DA 100 will start and run with the pickup plug in backwards, but won't achieve any rpm. Look at at the plug from the engine and make sure the wire colors match where it connects to the ignition. I'll bet money thats your problem. Hope this helps
