ignition timing
I have fitted an electronic ignition to replace the coil/flywheel on a 50cc petrol engine.
It has automatic advance built in. As a starting point, Do I set the sensor and magnet to just before top dead center or atmaximum advance ie. 28-30 degrees BTDC? |
RE: ignition timing
Depends on your ignition. Falkon ignitions advance from the initial setting so set them at 3-4 degrees BTDC. C&H type ignitions retard the timing from the initial setting so set them at 28-30 BTDC. www.falkon.cz or www.ch-ignitions.com
Keith BME |
RE: ignition timing
Error! Please disregard.
| All times are GMT -8. The time now is 10:58 AM. |
