RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Stihl conversion of 029 engine? (https://www.rcuniverse.com/forum/gas-engines-142/623675-stihl-conversion-029-engine.html)
Rcpilot 03-14-2003 07:01 PM
I'm almost finished with my Poulan Pro 54 engine.
I came across a Stihl model 029 saw for less than $30 at a local engine repair shop.
I believe this is about 55cc or 56cc.
Anyone done a conversion on this particular saw?
bn120 03-14-2003 08:39 PM
029 56.5cc yes I have done one the power is great but it is about 3/4 lb. heavier than the older 56.5cc the 031 and 032, you need to make a beam mount just like the poulan 42cc it is put together the same way and a carb mount that I can make for you if you like.the total weight after making a prop adapter carb mount and beam mount brackets will be a little over 4 lbs where the 031 and 032 will be just under 3 lbs so if you dont mind the weight then it would make a great power plant.it is also a drop in engine so no triming of the case is needed.I can make any parts for this engine you like just email me.
Darin
bn120 03-14-2003 08:50 PM
1 Attachment(s)
here is the 029 on a scale at 3.5 lbs no prop adapter ,carb mount and beam brackets and a shaved head and still weighs 3.5 lbs.
Darin
bn120 03-14-2003 08:52 PM
1 Attachment(s)
here is another pic.
Rcpilot 03-14-2003 10:44 PM
I got the saw this afternoon. It needed a carb.
I went to another small engine shop and got a used carb for $15.
This saw is in such good shape. I think I'll just sell it on Ebay. It looks like these saws are bringing around $150 on Ebay.
I've got $45 in it.
Nice work on yours bn120. Thanks for the reply and infom on weight.
bn120 03-15-2003 04:23 AM
you bet!
Darin
