Walbro question
I just got a Walbro carb with a bulb on the front.
There is a brass tube in that part of the carb and another which looks to be the one to connect the gas line to. How should this be setup. Thanks Larry |
Walbro question
1 Attachment(s)
My experience is with a Zama carb, but I have read they are hooked up the same.
The tube closest to the primer bulb goes to the fuel tank vent, and the other one goes to the fuel tank clunk. |
Walbro question
So the system is still just 2 lines, there's no vent? I
thought that was a no no for gasers. I flew it yesterday and worked pretty well with that bulb tube open. The only problem I was having was starting. It trys to start but dies. The best way it would start was to give it a couple clicks of throttle. It did run and fly but doesn't seem right. I was going to hook up like you said but was afraid to have a closed system. Thanks Larry |
Walbro question
For the best results solider up the tube for the primer bulb or seal it off with some fuel tubing heated up & pinched closed on the end and the vent line on the tank its self should be ran out the bottom of the plane. All I fly are gassers and this works good for me.
Keep'm Off The Ground!! Steve |
| All times are GMT -8. The time now is 06:02 PM. |
