What Size Engine?
1 Attachment(s)
I'm having some plans drawn up for the Piper Seminole. It's going to be 1/4 Scale. 115.8" wingspan. Thing is I don't really know what size engines I should start with. All up weight is estimated around 25 to 30lbs max. Probably more like 20 to 25lbs though.
Any ideas??? Regards, Bryan |
Another Picture.
1 Attachment(s)
What Size Engine?
TWO FOX 2.4'S OUGHT TO HAUL IT AROUND. NICE LOOKING BIRD. THESE ENGINES SWING A 20X8 MEZJLIK AT 7300 RPM WITH A BOLD MUFFLER INSTALLED. MIGHT BE EXACTLY WHAT YOUR LOOKING FOR.
What Size Engine?
I would go with fox but I want to go with two Gas Engines! Preferably weedwacker ones cause they are CHEAP on fuel and overall cost for the engines.
Regards, Bryan |
What Size Engine?
RYOBI 12lbs thrust each, you could hover if kept under 24 lbs LOL.
Darin |
engines
I bet 2 Zenoah 26cc engines would work nice. Capt,n
What Size Engine?
FOX 2.4'S ARE GAS ENGINES. THEY ARE FINE ENGINES. 20X8 MEZJLIK PROPS. ELECTRONIC IGNITION. THEY WEIGH 3LBS. JUST WHAT YOUR LOOKING FOR.
What Size Engine?
Mmm, where can I see those Fox 2.4's at?
Regards, Bryan |
What Size Engine?
WWW.FOXMANUFACTURING.COM CLICK ON "WOW" THEY HAVE A COMPLETE LINE OF SINGLES AND TWINS. FROM THE 2.4 SINGLE TO THE NOT RELEASED YET 11.6 TWIN. THEY ALSO HAVE A COMPLETE HOBBY SHOP FOR EVERYTHING YOU NEED. OR CALL TOLL FREE 1-877-FOX-3883 ASK FOR CHARLES. TELL HIM THE "HARDEE'S" BOYS SENT YOU.
What Size Engine?
Ok, thanks Stuka!
Regards, Bryan |
What Size Engine?
Mmm... Nice engines but I think the Fox 2.4 would be a bit overkill. The all-up-weight is only going to be about 25-30lbs. I'm looking for something more in the 25-30cc range. I want it to fly scale but with about 30% power reserves (just in case).
Regards, Bryan |
| All times are GMT -8. The time now is 04:00 PM. |
