Smoke
I understand that if I put a smoke nipple on the muffler of a gasser, it will melt the line directly attached to it. If this is true, how long should I extend the nipple with brass tubing, 1 1/2'' ??? :confused: Thanks in advance.
Smoke
what kind of hose are you useing? I use that black hi temp hose and have never had a problem.
Smoke
Use the black neoprene hose, you can get it from tower hobbies in 2 foot lengths for about $1, use this from the exhaust nipple to the check valve & from there you can use your tygon or whatever type you are using except silicon.
Gil |
Smoke
Thanks I'll try and get some of that black fuel line. The plain tygon looks like it will melt.
Peter |
| All times are GMT -8. The time now is 02:31 AM. |
