RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   BME 50 Engine How good of a engine? (https://www.rcuniverse.com/forum/gas-engines-142/7321864-bme-50-engine-how-good-engine.html)
FrankRC1 04-02-2008 11:58 AM
Looking to buy a BME 50 Engine for 1/5 scale Pica Spitfire. From what I seen on another web site the carb stick outside the cowel is this a problem?
karolh 04-02-2008 02:25 PM
RE: BME 50 Engine How good of a engine?
The BME 50 is an excellent engine, Spitfires however by their design have long narrow cowls so engines with side mounted carbs usually end up with the carb or it's intake partially sticking through a hole in the cowl, which is not a problem, just undesireable from a scale point of view. Engines with rear or front mounted carbs like DA or MVVS usually make for a much cleaner install.
Karol
Tired Old Man 04-02-2008 04:54 PM
And ZDZ. No issues with the BME for power and reliability, but the side carb could be an issue for you.
FrankRC1 04-02-2008 05:32 PM
Not worried about carb sticking out. My concern is with the carb sticking out will too much air from the prop cause a problem with how the engine runs. This kit Pica Spitfire is built with a beam mount for the engine that is why I am looking to use the BME 50.
Tired Old Man 04-02-2008 05:44 PM
Just FYI, Taurus makes the TS 52 with a beam mount if you order it that way. You shouldn't have any porbles with the external carb. Perhaps some fuel siphoning but that can be easily cured with a small deflector attached to the forward half of the venturi.
FrankRC1 04-02-2008 06:00 PM
Do you know of a web site I can get more information on the Tauras Engine?
Tired Old Man 04-02-2008 07:52 PM
[link]http://www.taurus-engines.com[/link] Basic info is there but he does business and pricing via telephone. Bill is a pretty good guy and takes care of you.
mrbassman 04-04-2008 09:40 AM
I have a BME 44 for sale. PM me if interested.
