RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   3w 140 engine problem (https://www.rcuniverse.com/forum/gas-engines-142/7519312-3w-140-engine-problem.html)
RIPRAP 05-20-2008 12:18 PM
Hi Guys hope someone can help here, i have a 3w140 that is difficult to start, the carb is clean and fine but it will only run on one cylinder at a time sometimes both together, then hops from one to the other the batt pack for the ign is 4.8v 1700ma, i have a feeling its the ignition pack has any of you out there had simalar problems with twins,
rc bugman 05-21-2008 04:30 AM
RE: 3w 140 engine problem
Hi,
I would suggest that it is the ignition. Usually, it is the spark plug caps which go bad and need replacing.
Elson
RIPRAP 05-21-2008 09:37 AM
thanks for that mate , looks like i need a replacement,The unit is stamped 1996, so 12 yrs old (but maybe not 12 yrs use)
rc bugman 05-21-2008 07:53 PM
Hi,
Try replacing the spark plug caps before you give up on the ignition. They are usually the component which goes bad.
Elson
