HELP WITH J TEC PITTS
just bought a j tec inverted pitts muffler for use on a da50r.along with the muffler came to extra pieces of metal stock.first one is rectangular and has a square cut out for exhaust port.this may just be to space the exhaust out?the secound piece is smaller rectangular with just to small bolt holes one at each end.the corner of the stock is cut off.this from what i have googled may be for braces but cant find a way to attach it.any help or pic would be great on there pupose
RE: HELP WITH J TEC PITTS
I have a Jtec fitted to a DL 50 and I think I got the same items. I threw them away and fitted the pitts directly to the exhaust port with a gasket in between. Have NEVER had a problem and I love the Jtec. If in doubt, just email them, they have an email address.
The rectangle is optional and can be used between the cylinder and muffler to move the muffler out a tad if needed for clearance. The other rectangle with just the 2 mounting holes can be used as a "washer" for the 2 mounting bolts for the muffler. This will aid in keeping the muffler bolts from distorting the muffler when tightened, thus keeping the bolts from coming loose.
| All times are GMT -8. The time now is 04:34 PM. |
