RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Zenoah G62 spring starter problems (https://www.rcuniverse.com/forum/gas-engines-142/7699679-zenoah-g62-spring-starter-problems.html)
black alder 07-06-2008 04:08 PM
My friend has a Zenoah G62 with the spring starter system. When he goes through the start procedure there is a terrific noise from the spring starter- it sounds metalic in nature. The noise is reduced slightly if he does not wind the prop back as far, however it is still present. He has taken it apart several times and everything is in place. He has also lubricated it with grease. There is nothing wrong with the engine, it runs just fine. The only problem appears to be with the spring starterI have friends with the same system and they do not get this noise.
Any input or suggestions would be appreciated.
Bluffman 03-25-2014 07:36 AM
I have this same problem it grinds when fully turned, and now-slips. Ian
w8ye 03-25-2014 07:58 AM
The problem with the spring starters is that they can never be wound tight or it will ruin the spring.
The one spring coil will pull down through two adjacent coils and then part of the coil will rub on the crankshaft.
I've seen this situation ruin the rear seal on some engines
All it takes is for someone to wind it too tight once?
Try a new spring.
Bluffman 03-25-2014 12:10 PM
I probably wound it to tight, I am taking it off which is a pain. Ian
jerdavis 03-28-2014 07:57 AM
1/2 turn is all the wind that is required to start the engine.
Jerry
Gizmo-RCU 03-28-2014 08:50 AM
Good read, I have one on a G38 and love it. Pull back past compression and let go. If properly primed it starts almost every time on the first try. I will be careful not to overwind!
ec121 03-28-2014 09:18 AM
I have a Quadra 40, half to three quarters pull is all that is required if it primed correctly. There are also conversion kits for the G62 to make it an electronic ignition. Horizon also has instructions on their site on how to set the prop and be able to flip start it.
flygilmore 04-04-2014 06:24 AM
Take the thing off...........you don't need it!!!! Extra weight and trouble. Learn how to hand start one, it's quite easy. I have been starting Zenoahs and everything else magneto under the sun for years with no issues.
Bluffman 04-04-2014 06:38 AM
Yes I took it off, it was cool to use, but I don't need headaches. Ian
