3W 170 BF2
Does any one know if the bolt pattern of the 3W 170 BF2 and the DA-150 are the same? I have a 40% Carden Cap and it had a DA-150 in it but I want to put the 3W 170 BF2 in it if it bolts right up.
Thanks |
RE: 3W 170 BF2
its not the same i think it carries the 157 3 dub pattern
I think DA 170 carries the same pattern as their 150 |
RE: 3W 170 BF2
Thx
RE: 3W 170 BF2
The bolt pattern of the DA150 and 3W157 are identical. The 157 is identical to the 170, so it should fit on the DA150 also.....
Greetz. |
RE: 3W 170 BF2
R U sure? I am confused. I was just told that it won't bolt up
RE: 3W 170 BF2
Alexzzz's info is incorrect.
The bolt pattern for the 3W 150 and DA 150 are exactly the same. The bolt pattern for the 3W 150 is different from the 157/170. The 3W157/170 is exactly the same. Hope that helps. |
RE: 3W 170 BF2
Okay
RE: 3W 170 BF2
ORIGINAL: ChickenStick Rick Alexzzz's info is incorrect. The bolt pattern for the 3W 150 and DA 150 are exactly the same. The bolt pattern for the 3W 150 is different from the 157/170. The 3W157/170 is exactly the same. Hope that helps. |
RE: 3W 170 BF2
b4 you get even more confused:
(732) 761-0997 http://www.aircraftinternational.com/ or email him at [email protected] (520)-721-0087 http://www.cactusaviation.com/ or email him at [email protected] post your results back here for more RCU to be educated on:) I already know the answer:D |
RE: 3W 170 BF2
I don't have to call or email anybody, I have all those engines (except the 3w170, but that is the same as the 157) here, but more important; Do you have those engines? Guess not;)
Here you have the proof[8D] If you are right, this shouldn't be possible, does it?[>:] http://www.modelbouwforum.nl/forums/...8-hpim5329.jpg |
RE: 3W 170 BF2
Alexzzz,
I think there is a misconception here. He is talking about the engine mounting bolt pattern, not the prop bolt pattern. You are correct they all have the same prop bolt pattern. But not the same engine engine bolt mounting pattern. I think that is where the confusion is. |
RE: 3W 170 BF2
Ahhhhh, I thought he was talking about the prop "bolt pattern", that changes things.....:D
RE: 3W 170 BF2
Yeah it is the mounting bolt pattern that I am talking about. So they are not the same correct?
RE: 3W 170 BF2
That's correct, they're not the same. But it's very easy to drill new holes? You will have lots of extra power with the 3W170:D The 157 also has some more power than the DA150.
Greetz. |
RE: 3W 170 BF2
Thanks alot for all your post.
SK |
| All times are GMT -8. The time now is 10:52 PM. |
