Please ID this engine
I picked this baby out of mud from near the lake side I fly at.
There is no brand what so ever printed on it, as far as I can see. The carb is a walbro and the ignition is a CH ignition unit that says "made in USA". I cleaned it out with water and now its cooking in the antifreeze bath. Once its clean enough I will dissasemble it to see if I can salvage it or not. Even if I do salvage it, I wont be using it on a serious airframe anyway. Just a fun and free project. Does anyone make out what brand and model it is from the pics? Here are the shots: http://i7.photobucket.com/albums/y274/dj_liquid/1-3.jpg http://i7.photobucket.com/albums/y274/dj_liquid/2-3.jpg http://i7.photobucket.com/albums/y274/dj_liquid/3-1.jpg http://i7.photobucket.com/albums/y274/dj_liquid/4-1.jpg http://i7.photobucket.com/albums/y274/dj_liquid/5-1.jpg Thanks! |
RE: Please ID this engine
BME something?? Not sure though.
Echo based. Possible 44. BME used the design, and a CH ignition, but I'm not certain of the prop hub. If you get it cleaned up and the crank is in good shape you'll have a good engine.
1 Attachment(s)
It is a BME for sure.:D:D What really gives it away is the lightening of the prop hub.:D:D It most lickly is the 50CC Classic.:D Although they did make a 40 something sport version Too!
I was going thru BME engine photos as suggested, and found this:
http://www.chiefaircraft.com/Models/...ME30CI50CC.jpg http://www.chiefaircraft.com/Models/...0_PITTS_MU.jpg I guess its a match.. BME 50 Classic? |
motorman, you drew it faster :D - wow I guess I will try my best to revive it then :)
where can I get replacement parts if I need them? (which I guess I will - at least a couple of them) |
BME Engines. Do a Google search for the addy.
same hub and same number of fins as the 50 pic, id say a 50cc bme for sure, but thats a guess.
It will be interesting to see if you can fix it up with little to no investment. You have nothing to loose.
http://bmeengine.com/ |
If you could get this cheap enough you could take the coversion parts off the old ingine and take out the engine block in chain saw and use them on it.
http://cgi.ebay.com/ECHO-MODEL-CS-44...1%7C240%3A1318 Milton |
My BME 44 had a 44 cast into the base on the front cylinder. Good Luck w/that project!
How is your engine clean-up and restoring project going. Good I hope. Best Regards capt,n
Well I tried to clean up as much as I could, but this engine is history. The crankcase is corroded - fins crack and break like biscuits, all the screws are corroded beyond repair - cant open it up.
I can see the inside from the carb opening and the conrod is fubar. probably so is the crankshaft, conrod needle bearings, normal bearings.. the carb is beyond repair, I would have to buy a new one. I tried to get off the muffler but one of the bolts broke so I drilled it out with a same diameter drill bit but the muffler is basically welded to the exhaust port - I couldnt remove it even with a heavy plastic hammer.. unfortunately the cost of repairing and restoring this engine is no where near logical.. Its probably been down in the lake for over 3-4 years.. Its kind of "case closed" :( |
| All times are GMT -8. The time now is 07:18 AM. |
