RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   MDL-28 & Evolution Prop (https://www.rcuniverse.com/forum/gas-engines-142/8984795-mdl-28-evolution-prop.html)
flyerdave 08-02-2009 08:37 PM
I have been using Evolution 18x6 wood prop on a Saito 180,but now I'm going to replace the saito with a MDL-28.What do you think of this engine -prop combo on a Dynaflite Decathlon? Thanks
BarracudaHockey 08-03-2009 03:23 PM
RE: MDL-28 & Evolution Prop
MLD28 :)
I used a 17x8 JXF and it pulled 8600 during breakin and the first couple flights. It gained a few RPM when it broke in and I switched to Royal Purple at 90:1
It was used in this review here: http://www.rcuniverse.com/magazine/a...rticle_id=1095
krayzc-RCU 08-03-2009 05:53 PM
that 28 seems to have good power from those numbers barracudahockey
3dsky 08-04-2009 02:32 PM
Evolution 18x6 wood prop is OK. My 1/4 scale CUB at 14.5 lbs I use a 17 X 8, 18 X 8 XOAR and an 18 X 10 . After break-in prop the engine to give better than 6800 RPM and you should have good performance. Keep a log of your RPM. You could break-in using the 18 X 6 and when the RPM increases use a 8 pitch prop.
krayzc-RCU 08-04-2009 04:25 PM
is anyone running one on a can or pipe?
